Old 09-08-2011, 12:59 PM   #1
81 C10AZ
Headliner?
Seems as if mine didn't come with one as I don't see any mounting points or remnants of one. Did some searching and found that not all of these trucks came with one.
Any one installed a headliner in a truck that didn't originally come with one? I'm wanting to seal the cab with sound deadener and more importantly a heat barrier.
Don't really want all that silver on my roof, want something nicer.
81 C10 2WD
Inline 6
A/C
81 C10AZ is offline   Reply With Quote
Old 09-08-2011, 01:02 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: Headliner?
contact cement is your friend
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-08-2011, 01:35 PM   #3
tucsonjwt
Re: Headliner?
As I recall, if you search the car interior supplier websites they will list headliners for both trucks with and without factory headliners.
Do you have all of the trim pieces around the roof to cover the edge of the headliner? If not, a local upholstery shop can make a headliner up for you with a finished edge that should look OK. With the stock trim pieces the headliner will just pop into place and be held up/trimmed out by those trim pieces. You can still buy those trim pieces new (LMC, etc.) or get them at the junkyard and clean/paint them up. My 83 headliner is made of a dense fiberglass material which I like better than the cardboard one - it is more flexible and adds a little insulation/sound deadening.
tucsonjwt is offline   Reply With Quote
Old 09-08-2011, 03:44 PM   #4
Papa_Smurf2
Papa_Smurf2's Avatar
Re: Headliner?
Rebel flag and some small self-tappers!!!
Nobody ever defended anything successfully, there is only attack and attack and attack some more.
George S.Patton
Papa_Smurf2 is offline   Reply With Quote
Old 09-08-2011, 04:25 PM   #5
Keith Seymore
Keith Seymore's Avatar
Re: Headliner?
My recollection is that Silverado came with a headliner; Scottsdale and Custom Delux did not (my '87 Scottsdale did not come with a headliner).
As mentioned, the headliner is held in place by the A pillar and side interior garnish trim.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-08-2011, 05:12 PM   #6
81 C10AZ
Re: Headliner?
It's a custom deluxe. No pillar trim.
I wouldn't mind it so much if I lived in a cooler climate, but when the exterior temp. gets 115, I want something more than sheet metal between me and the elements!
81 C10 2WD
Inline 6
A/C
Old 09-08-2011, 05:49 PM   #7
Altec
Getcha Pull
Altec's Avatar
Re: Headliner?
Time to hit the junk yards! Pick yourself up all the trim, and the headliner out of one that came factory with it. Install it in your truck by dry fitting all the pieces, and drilling pilot holes for all the pieces. It'll go right in.
This is funny, I just ripped all of the interior pieces out of mine...
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 09-08-2011, 06:13 PM   #8
81 C10AZ
Re: Headliner?
Looks like I'll be there tomorrow!
81 C10 2WD
Inline 6
A/C
Old 09-08-2011, 06:16 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Headliner?
If you want to sound deaden the cab and limit the heat, then try the "Lizard skin" approach.
http://www.lizardskin.com/
Frank
Old 09-08-2011, 06:25 PM   #10
81 C10AZ
Re: Headliner?
Interesting... Looks like there are two products for what I'm looking for. Cermaic coating for heat and Sound coating for sound deadening, both are $85/gallon. I'm gonna go take a look at the product tomorrow.
81 C10 2WD
Inline 6
A/C
Old 09-08-2011, 07:01 PM   #11
Keith Seymore
Re: Headliner?
LOL! Mesa, AZ is the reason my truck has A/C!
(I had already ordered my truck here in Michigan, and then learned we were moving to Mesa. I caught the order and had them add a/c to it).
We were there for four years, from 1989 to Jan 1 of 1994.
K
1979-1986
1986 - 2019
Old 09-08-2011, 07:30 PM   #12
76stepsidechevy
Re: Headliner?
My truck came with some god awful house carpet glued in for a headliner and behind the seat ect with construction adhesive. I ripped it all out and replaced it with some gray speaker box type carpet and installed factory trim I got from a member on here. I Used 3m spray can carpet adhesive and its held up fine all summer and with a leaking crappy sunroof im about to replace with a new one.
76stepsidechevy is offline   Reply With Quote
Old 09-08-2011, 07:36 PM   #13
Hevy
Hevy's Avatar
Re: Headliner?
Hahahaha!!! Awesome!!!
Hevy is offline   Reply With Quote
Old 09-08-2011, 11:18 PM   #14
piecesparts
Re: Headliner?
I am planning on doing the whole cab on my 68 project with this.
Frank
Old 09-08-2011, 11:26 PM   #15
Desert1957
Desert1957's Avatar
Re: Headliner?
^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^
worked for me on my "Custom Deluxe"
Desert
Desert1957 is offline   Reply With Quote
Old 09-09-2011, 03:50 AM   #16
masterlock
masterlock's Avatar
Re: Headliner?
Drill some holes in the roof from inside the cab and fill the entire roof with expanding foam then patch up the holes and paint it. My roof sounds like a surfboard when you tap it. It is filled solid with the foam. The cab isn't back on the truck yet but I'm sure it is gonna help with both heat and sound.
masterlock is offline   Reply With Quote
