Old 09-10-2011, 04:11 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Starts sluggish?
My 88 with 150K miles on it starts kinds slow to me. 800CCA battery thats around 2 years old, I dont know about the starter. Cold it takes about 5 full seconds to kick over and it isn't real fast. When it's warm its about 3 full seconds, still slow to me. What do you guys think?
I think I should take the cables off, scrub the ends to make sure they are super clean(no current corrosion though)and put some dielectric grease on the ends. And I also found out the plugs in my truck aren't the good stock AC Delco ones, they are Bosch Platinum Plus(ew). So I will spends the $15 and order some from RockAuto and gap them at .035 like they should be. Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-10-2011, 07:24 PM   #2
kris's66lwb
resident wrencher
Re: Starts sluggish?
Make sure taht all your connections are tight and rust free neg pos and down to the starter and the ground for the engine to the batt becarful with tte starter cable to the solinoid nut they like to break if too tight
kris's66lwb is offline   Reply With Quote
Old 09-10-2011, 08:30 PM   #3
broey
Square
broey's Avatar
bring the battery somewhere that has a battery tester, check the cca's after 2 years you probably are not at 800 anymore, I had the same issue, I just installed a red top optima, world of difference.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 09-10-2011, 08:41 PM   #4
WarBeard
WarBeard's Avatar
The starter in my Burb got really slow about a month before it went out totally.
Also the starter on my jeep got slow as well and I found out I had an oil leak and it was leaking on my starter and the insides were all oiled up. I took it apart and cleaned it all with brake cleaner and it is still working like a champ.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 09-10-2011, 09:31 PM   #5
thirdstreettito
Resident of Here
Thanks guys
~Bradley~
Miss having a truck
Old 09-10-2011, 10:54 PM   #6
Goldfinger
Goldfinger's Avatar
align and tighten the starter. this has helped me in the past.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
