Old 09-11-2011, 10:41 AM   #1
Pizzalovr36
exaust
should i get a 2-1/2 or 3in exaust?
Pizzalovr36 is offline   Reply With Quote
Old 09-11-2011, 10:45 AM   #2
eldogg
eldogg's Avatar
Re: exaust
need more info. engine size rpm range, how your gonna use it, etc etc.....
eldogg is offline   Reply With Quote
Old 09-11-2011, 10:51 AM   #3
Pizzalovr36
Re: exaust
its a 1970 chevy short stepside put in a 1980 5.7 350 going to run duel right out the back!
Old 09-11-2011, 12:02 PM   #4
cdowns
cdowns's Avatar
Re: exaust
i dont think there is much advantage running 3" exhaust other than to enrich the exhaust shop owner
Old 09-11-2011, 12:39 PM   #5
50bomb
50bomb's Avatar
Re: exaust
2 1/2 with dual flowmaster 40 series is what I will run on my 67 chevy lwb. But not sure if ima go all the way back or come out right behind cab/bed area before wheels. It will be a daily driver hopefully soon.
50bomb is offline   Reply With Quote
Old 09-11-2011, 02:46 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
Re: exaust
2 1/2
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-11-2011, 05:06 PM   #7
treveiger
treveiger's Avatar
Re: exaust
I'm gona do 2 1/2
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-11-2011, 05:50 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: exaust
There is no need to go any bigger than the smallest size opening in the system.
From the exshaust manifold out is no better than the opening in which the pipe is connected to. If your manifold is a 2 1/2 opening then thats as big as you need.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-11-2011, 07:50 PM   #9
hugger6933
Re: exaust
2 1/12 inch is more efficent than the 3 inch. To need the bigger pipe you need a LOT of motor. I'm talking wild big-inch small block or blower stuff, big big-block. Some of those even can do a 2 1/2 inch pipe on a driver and be fine , but an eq tube would help.
hugger6933 is offline   Reply With Quote
Old 09-11-2011, 09:18 PM   #10
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: exaust
stock 2 inch -mild 2 1/2-prof-3
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
