Old 09-11-2011, 01:20 PM   #1
pat565
71 Lower control arms
What options are there to replace a set of lower control arms with a drop spindle? I would like a bolt in deal with the shafts already in place
I was going to reuse the originals, but the threads where the bushings go are pooched.
Thanks, Pat
pat565 is offline   Reply With Quote
Old 09-11-2011, 06:01 PM   #2
70chevytruck
Re: 71 Lower control arms
Me too....threads are toast on both uppers and lowers on mine. New ones from Jegs or similiar aren't too bad price wise.....
70chevytruck
70chevytruck is offline   Reply With Quote
Old 09-11-2011, 06:37 PM   #3
pat565
Find me a better price than $1450! ouch!!!
Old 09-12-2011, 12:35 AM   #4
SCOTI
SCOTI's Avatar
$1450? For what/where?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-12-2011, 06:47 AM   #5
Rochlow
Control arms set up for airbags, coil spring or coils overs..
Rochlow is offline   Reply With Quote
Old 09-12-2011, 02:23 PM   #6
pat565
Lower control arms for springs.
Old 09-12-2011, 02:26 PM   #7
pat565
That was the pricing at Jegs, for an aftermarket setup
I would be happy with stock replacement, but I can't find any complete ready to bolt in. I'm not taking a chance on another set being stripped out, etc.
Old 09-12-2011, 02:31 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Switch to a set of 73-87 control arms.
They have press in rubber bushings.
Should be plentiful in junk yards or Craigslist.
Might even be some in our classifieds section.
Keith
Convert to disc brakes.
Old 09-12-2011, 02:33 PM   #9
pat565
Are they a direct bolt in or do I need more parts to make it work, like sway bar, etc?
Old 09-12-2011, 02:41 PM   #10
lolife99
lolife99's Avatar
Direct bolt on.
The 73-87 arms take a slightly larger u-bolt to hold them to the crossmember saddles. (9/16" vs 1/2" I think).
That's what drills are for.
Keith
Old 09-12-2011, 04:04 PM   #11
SCOTI
SCOTI's Avatar
Direct bolt on.
Technically, you can still use the smaller u-bolts. The ID of the u-bolt where it fits the control arm shaft is the same. The diameter of the actual u-bolt is larger for post-73 suspensions (9/16 vs 1/2").
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-12-2011, 08:25 PM   #12
pat565
CPP lowers ordered from Scott's Hotrods (Justin)
It's way eaiser to buy this stuff from the States than locating up here in northern Alberta.
Old 09-13-2011, 08:43 AM   #13
70chevytruck
http://www.performanceonline.com/Tub...-Control-Arms/
70chevytruck
