Old 09-12-2011, 10:32 AM   #1
SamMargritz00
SamMargritz00's Avatar
Top Texture.
Hi, just about to start fixing up the top on my 72. I was just wondering if it were possible to get the top to look smooth instead of the rough texture it already has. im not really wanting to go at it with the sander.
SamMargritz00 is offline   Reply With Quote
Old 09-12-2011, 11:03 AM   #2
turp mcspray
turp mcspray's Avatar
Re: Top Texture.
The way I see it, there are two ways to get it smooth, without going at it with a sander.
Hire someone else, to go at it with a sander, or have it blasted.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-12-2011, 01:59 PM   #3
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Re: Top Texture.
I'm no paint or body guy, so take this at face value. If I were doing it, I'd shoot it with some high build primer, and work it from there. This way you're removing the primer to smooth it down as apposed to removing the factory 'glass. Or, and I'm not sure either of these would work in a real world, you could put a skim coat of filler over the entire roof and sand it.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 09-12-2011, 09:09 PM   #4
mcampbell
Re: Top Texture.
I smoothed a top years ago and it was not glass but sort of a spray on texture that I thought came off pretty well. I used an air file with pretty fine grit paper. Some idiot had cut a one foot square vent hole in the center that needed to be glassed in and the texture sanded off a lot better than the fiberglass repair.
mcampbell is offline   Reply With Quote
Old 09-14-2011, 08:01 AM   #5
Bentblazer
Bentblazer's Avatar
Re: Top Texture.
IMO sanding the original texture off isn't really that hard, plus you would be able to see any cracks that are hidden that would show up if your are wanting a smooth finish.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 09-15-2011, 09:04 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Top Texture.
With the "texture" sanded off you could then apply some resin and see the 30+ year old (and dry)fiberglass suck it up.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
