#201 |
Grandpa in the rustmobile...
Re: Post your best budget mods! ($50 or less)
Need to think/remember about the door seals...good idea guys
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#202 |
![]() Join Date: Mar 2010
subscribing - love this thread
#203 |
Get a distributor re-curve kit and experiment. Really helped the torque and mileage on a 250 six. Kit was for a V8 but the springs worked fine.
#204 |
What?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#205 |
I could never see my climate controls when driving at night. So i bought a led light strip (under $10) and trimed off a group of 3 lights...spliced into my dash lights and stuck it to the bottom of the ashtray...closed the ashtray, turned on headlights and works great! Actually a little too bright at first, had to cover 2 of the lights with elect tape...perfect now. It even illuminates my console cup holder in the floor board. I'm thinking about using the rest and mount under the seat for some more floor board illumination. Anyway, cool trick thought id share.
#206 |
Not too old to learn
That is a ahem... "brilliant" idea.
1968 C10 a way to long restoration. |
#207 |
Old member
Can you explain how you tied into the LED's?
That may be something I need to do latter on. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#208 | |
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#209 |
Has anyons done the camaro gauge mod... I'm looking for the HOW TO for it
#210 |
I have some repair tips that aren't mods but they'll get you home if you need to. I've already seen the photo of pantyhose used for a belt and I can tell you from personal experience that works. Here are some others.
Aluminum foil dipped in coke will remove surface rust from chrome and make it look new. WD-40 wiped on seals will help them last longer. A matchbook is the correct thickness to set point gap. A number one paper clip (most common) is the correct spark plug gap. 800 grit sandpaper will make wipers clean better. A papermate pen (once the guts are removed) makes a very good hose splice. Pepper or an egg white will temporarily seal a radiator leak. Aluminum foil can be used to improve an loose electrical fitting. WD-40 can be used to reseal the bead of a tire that is off the rim. And finally you can weld a broken shift linkage on the side of the road with jumper cables and a penny. (Got me my nickname) |
#211 | |
Sheetmetal Psycho
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#212 |
DIY fan shroud guide. Must be under $50,- didnt check that though!
http://www.cadvision.com/blanchas/54...FanShroud.html
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#213 |
Hello Scott. Yes, if you ground the item to weld then grab the penny with the positive lead, you can create an arc using a battery and weld. at least enough to get you back on the road.
#214 |
How 'bout a $20 electric windshield washer pump so you get a nice even consistent spray. Especially nice in the winter. Simply install a bulkhead fitting on the bottom of your reservoir, mount the pump below that. Then you only need to rerout the washer fluid lines and run the hot lead from your switch to the pump, and ground the other lead.
#215 | |
I thought the switch in the dash controlled the ground wire so was planning on running the ground from the new pump through the switch. Is that not correct?
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
#216 |
I don't recall off the top of my head. I just ran both wires from the old pump all the way up to the new pump.
#217 |
bump
#218 |
Cool tricks and ideas, subscribed!
#219 |
Hollywood
How about using black shoe polish on black plastic to bring the color back to new or weatherstipping
1968 cSSt shortbed 1971 custom deluxe shortbed frame off 1991 caddilac escalade ST shortbed 1992 chevy ext. cab Project: leftovers 2003 Silverado ext. cab shortbed (my dad's truck R.I.P.) 1969 trans am clone, pro tour 1985 Yamaha Vmax, custom 1993 Yamaha Vmax, showbike 1969 Sears Suburban SS12 lawn tractor |
#220 |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#221 |
How about the Jeep door checks. I heard about them working in the 60-66s but couldn't get confirmation about wether they work in my 67 or not. I heard $8 per in a JY?
http://67-72chevytrucks.com/vboard/s...d.php?t=446066
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#222 | |
http://outintheshop.com/faq/Vac%20Adv%20Spec.pdf |
#223 |
For those of you that kinda know me or of me would'nt be suprised to find out that this a bodyshop cheapee. Take an old coffee maker out to the shop plug it in fill'er up in about five min. you are ready to wetsand with warm water. It is very usefull in the winter months and I tryed it not long ago thinking why have I not done this sooner. Wetsanding is a miserable enough as it is without having to dip your hand in freezing water! cost on this tip $00 if you have an okd one but even if you don't and need to do this 20 bucks at a dollar store will put you in bussiness
#224 | |
#225 |
When painting the dash cluster, what do you do about the lettering and numbers?
