Old 09-13-2011, 03:23 PM   #1
kikkegek
kikkegek's Avatar
help identify my engine
2nite I tried to indentify my engine.
all I could find on the driver side behind the heads was this:
Am I looing at the wrong spot?
all I can see is GM 5.71 C
and I looked where the red arrow is...
kikkegek is offline   Reply With Quote
Old 09-13-2011, 03:38 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: help identify my engine
Pretty sure that says GM 5.7L C which is a 350.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-13-2011, 03:46 PM   #3
kikkegek
kikkegek's Avatar
Hi thanks, for that. But shouldnt that be where my casting number should be?
Or is that in a different place?
Old 09-13-2011, 04:16 PM   #4
sean1969c10
sean1969c10's Avatar
You have a later style one piece rear seal block. That is where the casting number is on a 2 piece seal block.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 09-13-2011, 04:29 PM   #5
kikkegek
kikkegek's Avatar
he thanks man!
where do I find it on my engine then?
Old 09-13-2011, 04:58 PM   #6
russgt
russgt's Avatar
1980 to 1985 350's have the same 5.7L cast into it and are 2 piece rear seals but they also have a casting number near that.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 09-14-2011, 07:05 AM   #7
kikkegek
kikkegek's Avatar
hi thanks, but my car is from 86 and dont see a casting number there. So I am wondering if there is anybody here with a 86 or 87 model engine that can help me?
Old 09-14-2011, 07:54 AM   #8
BigBlocksRule
Go by O'Reilley's or AutoZone and get a can of cheap brake parts cleaner. It comes with a straw, you can use it to clean all the greasy oil off of the block in that spot so you can read it. It'll be a ton faster than trying to scrape it off. Just make sure not to do it on your driveway, all the dissolved grease, etc. will drip...and let it set for about 10 - 15 minutes after you're done to let any excess evaporate.
BigBlocksRule is offline   Reply With Quote
Old 09-14-2011, 09:28 AM   #9
sumran
sumran's Avatar
I have an 86 block. Thje casting number is on top rear edge of the block, driver's side of center. Mine is a 305 so it may be different on yours.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 09-14-2011, 09:43 AM   #10
Your41Plague12
My 350 is in the same place. Rear edge of the block (where the bellhousing bolts to the engine), driver's side of center. Pain in the behind to get to if you don't have a body lift.
Steve
Old 09-14-2011, 11:46 AM   #11
sumran
sumran's Avatar
Mine is easy. It is on a stand.
Randy Summers
Old 09-14-2011, 01:46 PM   #12
kikkegek
kikkegek's Avatar
can you see it from the top when looking down in the engine bay over the back of the engine between the firewall and the engine?
@sumram: if its a 86 model engine, please post pics of where yours is at...
Old 09-14-2011, 03:57 PM   #13
Your41Plague12
Sure can. Just hose it down with oven cleaner or brake cleaner or something. Engine degreaser also works well if the deposit isn't too heavy, so I'd scrape all you can off of it and hose it down.
Steve
Old 09-14-2011, 04:02 PM   #14
kikkegek
kikkegek's Avatar
I'l try to do so this weekend and report back. thanks!
Old 09-14-2011, 04:08 PM   #15
Your41Plague12
No problem, man. Hope it works for you. I tried engine degreaser on a 366 I was messing around with, and it worked for small stuff, but the heavy deposits needed scraped off.
Steve
