Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-15-2011, 12:19 PM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow For all the racers looking for a 400ci SBC
1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
http://67-72chevytrucks.com/vboard/s...07#post4900807
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-15-2011, 01:48 PM   #2
C-10 simplex
Re: For all the racers looking for a 400ci SBC
If i could ask a related question; Are the new bowtie sportsman blocks such as 12480175, 12480157 and 159 actual 400 blocks?
What i'm trying to get at is are these essentially "new 400" blocks as an alternative to looking for and buying used?
C-10 simplex is offline   Reply With Quote
Old 09-15-2011, 02:10 PM   #3
1Bad62Pro/Street
Arrow Re: For all the racers looking for a 400ci SBC
I think there are just 350 blocks made into 400 cubic inch.
http://www.jrgmparts.com/GM_Performa...y_small_b.html
GM Performance 12480175 - GM Performance 350 C.I.D. Cast Iron Racing Bowtie Bare Engine Blocks
http://www.summitracing.com/parts/NAL-12480175/
GM Performance 12480157 - GM Performance Bowtie Sportsman Engine Blocks
http://www.summitracing.com/parts/NAL-12480157/
GM Performance 12480159 - GM Performance 350 C.I.D. Cast Iron Racing Bowtie Bare Engine Blocks
http://www.summitracing.com/parts/NAL-12480159/
Old 09-16-2011, 01:20 PM   #4
C-10 simplex
i.c., so this could be an alternative to getting 400+ cubes AND have all the advantages of a 383 stroker because these blocks can also take a 3.75" or greater crank?
So this could be an alternative to trying to find a good 400 block? i know that the bowties probably cost at least 2K, but when you consider the time savings etc.........?
Old 09-16-2011, 01:30 PM   #5
dbmx66
you just have to watch how much you bore and stroke it, on 400 blocks the cylinders are very close together. and if you need to clearance the block for a larger than 3.75 stoke your gonna be in the water jacket. unless you do it carefully.
dbmx66 is offline   Reply With Quote
Old 09-18-2011, 12:27 AM   #6
C-10 simplex
i guess what i'm trying to get at is maybe this could be a way to get 400 cubes in a small block without trying to hunt down an actual original 400 block.
i know the price is a little steep but it could save a lot of time---what if you did manage to find an original 400 block only to find that it's too cracked up?
Old 09-18-2011, 07:18 AM   #7
1Bad62Pro/Street
The (BEST) and (WORST) Small Block Chevys Engines Of All Time
http://67-72chevytrucks.com/vboard/s...d.php?t=386581
The only block of this family, 400 cu in (6.6 L) small-block, was introduced in 1970 and produced for 10 years. It was loosely based on the medium journal 350 and had a 4.125-inch (104.8 mm) bore and a 3.75-inch (95.3 mm) stroke. The 400 differed from other small blocks in that the cylinders were siamesed, used a 2.65” large journal, and oftentimes had one more freeze plug on both the left and right sides of the block. Initial output was 265 hp (198 kW) and was only available equipped with a 2-barrel carburetor. In 1974 a 4-barrel version of the 400 was introduced, while the 2-barrel version stopped production in 1975. 1976 was the last year that the 400 was used in a Chevrolet Passenger car, available in both A-Body and B-Body lines. While popular with circle-track racers and drag racers, the engine was prone to cooling troubles if cylinder heads without steam holes were used.
Old 09-18-2011, 07:38 AM   #8
1Bad62Pro/Street
As far as buying used engines you have inspect the engine over and know what to look for. If the engine is together it makes it harder unless you know the person very well. There is alot of untrustworthy people out there looking for a dollar and will lie cheat and steal with a smile. The thing with crate engines is that they come with a Warranty. (read fine print)
They are Pro's and Con's between both. I rather have the old stuff.
But if I was looking for a crate engine... I would go for the Edelbrock Crate Engines.
Jegs Engine - Assembled / Ready-to-Run
http://www.jegs.com/c/Engines-Compon...10763/10002/-1
Summit Engine - Assembled / Ready-to-Run
http://www.summitracing.com/search/P...Crate-Engines/
Old 09-18-2011, 11:22 AM   #9
Marv D
Registered Truck Offender
Marv D's Avatar
C-10 IMO that is very sound thinking. And in line with what your looking for.... The Dart Little M, or the Motown is the 'ideal' 400 block with 400 mains. I've got one of each in my own personal junk and so far can't say I have an opinion on which is better than the other. The Motown got a bit of a bad rep over the internet 5 or so years ago, But I've been running one as a 434 at 800 n/a HP and shifting at 7600rpm in the Nova since 2004.
All of the 'ills' of the production casting is cured in these aftermarket blocks.,, solid deck thick enough to have blind holes for all the head studs,, main web problems, cylinder walls thick enough to tolerate a 4.20" bore and still handle 1000HP, TRUE proprity main oiling.
The Dart 'SHP' block is only offered in 350 mains (even tho capable of a 4.20 bore also) but is a VERy solid platform too and a bit les than the Little M.
But speaking of little M....
these things always look so funky as a porcupine I just had to share
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-18-2011, 09:44 PM   #10
Marv D
Marv D's Avatar
1bad,, actually sorry dude, didn't realize it ws you that had a GM block for sale in the listing. Wouldn't have harped on the GM casitngs if I had realized,, now I cn't fricking edit it!
DOH!!!
Old 09-18-2011, 10:01 PM   #11
1Bad62Pro/Street
Wink Re: For all the racers looking for a 400ci SBC
No problem Bud.
It's all good.
I'm selling this for my dad. It was gave to him for some work that was done.
Alot of guys love these 400's for racing. So I just posted it here just just in case there were anyone in NC/SC folks that lived close buy.
Casting # CID Year Model Application Comments
3951511 400 70-73 Pass,Chevelle,Monte 4 bolt main, 3 freeze plugs/side
3951511 400 75-80 Truck 4 bolt main, 3 freeze plugs/side
Chevy 400 cu in SB out of a Chevy K-20
.030 over Good Hone No Land
Casting 3951511 Canadian 4 Bolt Main Block
3 Freeze Plugs
Balanced Rotating Assembly
I-Beam Rods Cleared for High Lift Cam
COR Hypertec Aluminum pistons Dish Type
.010 cast crank 3951528 - Low miles
Good Clean Polished Finish
needs Decked and some Heli-Coils Installed
$400.00 OBO
NC 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
1bad62prostreet@gmail.com
