Old 09-16-2011, 08:43 PM   #1
1SS
1SS's Avatar
Won't move
I just got done re-doing the entire suspension and steering on my 72' K10. Now the truck will not move when I let out on the clutch. The drive shafts still appear to be where they are supposed to be. I don't know if it is the parking brake or not becuase the engine doesn't even think about lugging. If it was the brakes I figure the engine would lug when you let out on the clutch. The truck ran and drove fine before I did the steering and suspension. Any thoughts??? Oh yeah, and the parking brake is pretty jacked up so if any of you know where I can get parking brake cables and such for my 4x4 that would be some great info to have too. all I can find on year one and LMC is C10 stuff.
1SS is offline   Reply With Quote
Old 09-16-2011, 08:51 PM   #2
bigbadchev72
People know me
bigbadchev72's Avatar
Re: Won't move
Jack it up and try to turn the wheels, should be able to narrow down the problem from there.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-16-2011, 09:27 PM   #3
OrrieG
OrrieG's Avatar
Re: Won't move
engine doesn't lug when clutch is out but not moving? isn't the clutch disc slipping? if the wheels are not moving and clutch is engaged the engine should die. if not and clutch is not smokin, is the transfer in neutral? i'm a little confused. don't know about 72 but I think the 74 c10 and k10 donors i used has the same ebrake setup.
Old 09-17-2011, 10:51 AM   #4
LONGHAIR
Re: Won't move
Sounds to me like the transfer case is in neutral. Don't just go yanking it in gear though, if you have let the clutch out. The in-put shaft is turning so the gears will grind. Shut it off, put the transmission in neutral and then try to shift the transfer case.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-17-2011, 11:51 AM   #5
onebadbowtie
onebadbowtie's Avatar
Re: Won't move
check all your clutch linkages. mine did this once. it would run and could put in any combination of gears and wouldnt go. the clutch linkage came off the clutch fork. put it back together and was good to go. see my build thread. it was discussed on there if you need more info
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 09-17-2011, 12:14 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: Won't move
Transfer case in neutral?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-18-2011, 02:58 PM   #7
1SS
1SS's Avatar
Re: Won't move
It might be in neutral. I dont have a knob on my t-case lever. What is the sequence for 2H, 4h, 4L and N?
Old 09-18-2011, 03:20 PM   #8
Redcap
Re: Won't move
Which T-case do you have?
Redcap is offline   Reply With Quote
Old 09-19-2011, 08:43 PM   #9
1SS
1SS's Avatar
Re: Won't move
Uhhh...
Old 09-19-2011, 08:46 PM   #10
str8axle55
Unhappy Re: Won't move
Had this happen before.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
