#101 |
Re: (( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
Wow! These trucks are so far out of my league that I don't know where to start. I have a '66 Chevy C10 SWB pickup that I just want to replace the engine in. It currently has the 250 six cylinder and I want to put a V8 in it. I am not a mechanic and I don't even know where to start ( such as what motor will fit without rebuilding the whole truck ). This truck will be just for everyday driving, not a showpiece. I guess I just want suggestions or comments from someone who has been there before and knows what all I am going to encounter. I have owned the truck for 38 years and it is in very good condition, just needs a new motor. Any help that you may provide will be greatly appreciated.
#102 |
![]() Join Date: Oct 2009
For V8 options, 66 came stock with a 283 or 327, so any small block chevy will easily fit (and all accessories, etc are easily available) - so, 283, 327, 307, 305, 350. Easiest is a 350 since they practically grow on trees, but a 283/327 of somewhere mid-60's vintage is a cool addition. If you're not up for a rebuild yourself of the junkyard small block, a crate engine is probably right up your alley. In addition to the above stock cubes, crate motors are generally found in a 350 or 355 (bored 350) or 383 (bored/stroked 350). If you go crate, 383 is a vrery good option. Recommend a head to toe (carb to pan) running engine since you you won't have the add-ons (water pump, distrib, manifold, carb, etc etc) to swap from you 6 cyl. You may still need to do a little shopping (or a large swap meet usually has refurbished ones) for some a/c, alternator, and power steering pump brackets (if you're running any of the upgrades like ps/a/c, etc). You will need V8 motor mounts, and they should bolt right into your frame and onto about any small block. Personally, I'd swap the tranny out too - if you're looking for a driving machine - the powerslide auto or stock 3/4-speeds leave a little to be desired in my opinion. Remember, you've always got the forum to ask the stumpers you run into - guaranteed someone on here has an answer. No guarantee it's the RIGHT answer, but, you get the idea... Only way to learn is to dive in. Sounds like a blast, good luck!
#103 |
Senior Enthusiast
And welcome to the forum!
#104 |
Hey thanks for the information. That is exactly what I was looking for. One other question (for now anyway). If I choose to go with the 350 engine which seems to make the most sense, do I need to get a wiring harness for that engine since it will probably be totally different from the exixting 6 cylinder.
#105 |
"Where were you in '62?"
![]() Join Date: Jul 2004
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#106 |
![]() Quote:
#107 |
Customized to the max:
#108 |
Convertible:
#109 |
Senior Enthusiast
#110 |
#111 |
Carpet dash???
That steering wheel has to go!!! ![]() ![]() http://fortwayne.ebayclassifieds.com...ck/?ad=8813615
#112 |
#113 |
The PT truck is just sick...
Posted via Mobile Device |
#114 |
Saw this on a 64 at Billetproof California today. It's subtle and it's more practical than attractive, though I think it looks good.
Check out the screening below the cowl.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#115 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Maybe painted an accent color, or matching the body paint would be better. It doesn't look bad, but could possibly be better. Any pictures of the whole truck?
#116 |
Thought you would never ask.
#117 |
A few more.
#118 |
But Found Her 25yrs Later!
#119 |
Senior Enthusiast
That is one of the most amazingly detailed trucks I've ever seen.
#120 |
GMC's n H.D.'s too!
WOW, that is a beautiful truck!!!
#121 |
#122 |
A wild '55 Chevy Kustom at the Long Beach Motorama 2011
Not a 60-66........ But you get the idea on the customized bed! ![]() http://67-72chevytrucks.com/vboard/s...48#post5038048
#123 |
Easy Does It
Filling the seams along bedsides and hood. I did this to mine -I think it looks alot smoother/ cleaner. Also filled in the turn signal holes and stake pockets.
#124 |
Altered Stepside Bed and Tilt/Dump Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=283107 Impala bumper '62: http://67-72chevytrucks.com/vboard/s...d.php?t=502690
#125 |
Hay is not that blue truck the same one that they are building in Custom Classic Trucks?
