Old 09-13-2011, 09:53 PM   #1
77c10
77c10's Avatar
Headlight bezel question
Anyone know of a headlight bezel that will work with the combo in the picture below? I tried #36-4332 from LMC but it is for the big single headlight. I currently have the small rectangle headlight. I tried to switch it to the big one but it will not work.
Last edited by 77c10; 09-13-2011 at 09:55 PM. Reason: trying to get the pic to post
77c10 is offline   Reply With Quote
Old 09-13-2011, 09:56 PM   #2
Papa_Smurf2
Papa_Smurf2's Avatar
Re: Headlight bezel question
lmc?
Nobody ever defended anything successfully, there is only attack and attack and attack some more.
George S.Patton
Papa_Smurf2 is offline   Reply With Quote
Old 09-13-2011, 09:59 PM   #3
grs
What year is the truck?
grs is offline   Reply With Quote
Old 09-13-2011, 10:04 PM   #4
77c10
77c10's Avatar
The truck is a 77. The previos owner put a later model grill and the square headlight. When I bought it there were no bezels. LMC= LMC Truck parts
Old 09-13-2011, 10:05 PM   #5
77c10
77c10's Avatar
Originally Posted by Papa_Smurf2 View Post
lmc?
LMC Truck
Old 09-13-2011, 10:37 PM   #6
my4by2
my4by2's Avatar
That headlight looks to me to be like the upper one from the two (stacked) headlight model trucks (like this pic I got online) so that grille & bezel set are all wrong... You would need the correct bezel, lower headlight & to move the marker light into the grille assembly as well. You can get all of these parts new from LMC Truck, Brothers or several other manufacturers.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 09-13-2011, 11:00 PM   #7
rwhit57
rwhit57's Avatar
The 82-83 I believe had that set up, but the headlight as mentioned was larger.
rwhit57 is offline   Reply With Quote
Old 09-13-2011, 11:11 PM   #8
rwhit57
rwhit57's Avatar
Like this, these are pics from here.
Old 09-13-2011, 11:26 PM   #9
VegasBruce
VegasBruce's Avatar
It looks to me, like the PO wanted to use '80 Silverado bezels.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 09-14-2011, 07:51 AM   #10
77c10
77c10's Avatar
Does anyone know if the radiator support from an 80 model will bolt into my 77? The reason why the bigger single lights will not work is because the radiator support is made differently where the headlight buckets go.
Old 09-14-2011, 08:01 AM   #11
Your41Plague12
Your41Plague12's Avatar
Yes, the rad support will bolt in. That's providing you have a 73-80 hood and fenders. It's a bolt-in deal. Looks like you have 81-87 fenders though, and probably a hood. I'd swap back to the 70's style if it were me.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-14-2011, 08:48 AM   #12
77c10
77c10's Avatar
The hood is an aftermarket fiberglass cowl hood so I really dont know what year it is. The fenders have the marker lights that are mounted horizontally.
I guess I know now why the previous owner never installed headlight bezels...
Old 09-14-2011, 09:41 AM   #13
Your41Plague12
You have a mismatched fender/rad support setup. I'd get a different rad support and run the 81-87 single headlight setup. The 80 rad support won't work with your fenders.
Steve
Old 09-14-2011, 09:45 AM   #14
77c10
77c10's Avatar
Thanks for the help guys, guess I will be hitting Pull A Part looking for the core support this weekend.
Old 09-15-2011, 11:46 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
if those are 2 of the smaller 4 light system you won't have high or low beams then
the buckets for the 4 lights are notched in the corners for high and low beam bulbs to fit
how may plugs on the harness for them?
how many tangs on the bulb?
the notches on the front of the fenders wouldn't be there on 77
wipers would be under the hood not over the seperate cowel on a 77
my red 78 and gold 88
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-15-2011, 01:45 PM   #16
Your41Plague12
Check and see if you can take the headlight bezel out and bolt the headlight in where the turn signal currently is. If so, you could do some wiring and make it a quad headlight setup and be fine. I personally didn't think a 73-80 rad support would bolt to 81-87 fenders, but I've been wrong before.
Steve
Old 09-15-2011, 04:15 PM   #17
77c10
77c10's Avatar
I went ahead and removed the core support last night. It was only bolted in at the top. I plan to get a support from a 81-87 this weekend.
Old 09-15-2011, 04:18 PM   #18
Your41Plague12
Ok cool, I didn't know if they would bolt together or not. Better safe than sorry I guess. I imagine a core support shouldn't be too hard to find from a single headlight truck, they were everywhere back in the day.
Steve
Old 09-15-2011, 04:33 PM   #19
77c10
77c10's Avatar
They are pretty plentiful at the local Pull-A-Part. I plan to go back and get the one out of the truck that I took the headlights from.
Old 09-19-2011, 08:06 AM   #20
77c10
77c10's Avatar
Went to Pull-A-Part yesterday and got the correct core support. Hopefully I will get it installed tonight. I will post pics once I do.
