Old 09-19-2011, 10:04 PM   #1
Rifter_Chevy
Backfire
Hello all, so today on my way to work the truck started backfiring. Not real bad but definatly noticable. It only does it at above 20-30% throttle, if i keep my foot off it it runs smooth as butter. Doesnt do it at idle at all, does do it in neutral if i rev it up.
Background on truck, never backfired before ever. Owned for 9 months. Changed carb 2 months ago has been running fine since. Wires/plugs/HEI distrubutor all brand new 9 months ago when purchased. Checked/adjusted timing 2 months ago when i installed new carb.
Its a small block 350 all stock except edelbrock 650 AVS off road carb.
What do you think i should look at first?
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case
Rifter_Chevy is offline   Reply With Quote
Old 09-20-2011, 08:21 AM   #2
sumran
sumran's Avatar
Re: Backfire
I would verify timing and be sure you are getting proper advance. Carefully check distributor cap and internals.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 09-20-2011, 08:44 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Backfire
definately sounds like something in the vacuum advance , but like he said check out the cap for a hairline crack or deposit
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-20-2011, 09:22 AM   #4
njlimbaugh
Re: Backfire
Look for a vacuum leak.
njlimbaugh is offline   Reply With Quote
Old 09-21-2011, 03:15 AM   #5
Rifter_Chevy
Re: Backfire
found the issue, was a loose/barely connected spark plug wire.
The Previous owner decided it would be a good idea to use 5, yes 5, different spark plug wire brands/types so all the boots are a differnt design/thickness/color so when i visually look at them they all looked connected but when i took the cap off one fell off so it obviously wasnt connected properly. All is well now.
I hate people who shouldnt be working on cars(like the guy i bought this from)
Old 09-21-2011, 07:45 AM   #6
sumran
sumran's Avatar
Re: Backfire
Glad you fixed it. If the P.O. hadn't frustrated himself, he might not have sold it to you.
Randy Summers
Old 09-25-2011, 11:14 PM   #7
Rifter_Chevy
Re: Backfire
Ok new issue!
So since i fixed this last week its been fine, put over a tank of gas through it and no issues. Then comes the drive to work today.
So now its i think a different issue as it does it at different times.
Now it backfires ONLY at low throttle, if i floor it it will backfire like CRAZY for 1-2 seconds(like 20-40 pops in that 1-2 seconds, sounds like a popcorn machine is under my feet) then it kicks in and runs fine and pulls hard right till 5000+ rpms. If i apply like 40-60% pedal sometimes it backfires a little sometimes it does not.
Does not do it cold at all only after warmup. Unlike last week this time it DOES NOT backfire at all in neutral, can rev it up all i want with all kinds of pedal pressures in neutral it will not backfire.
So before i drive it off a cliff what should i look into this time.
EDIT to add, what makes me think its unrelated is last week was very small pops through the tailpipe, very small backfires. This week its much louder and much closer together with the poping sound.
Old 09-26-2011, 12:29 AM   #8
Your41Plague12
Your41Plague12's Avatar
Re: Backfire
Sounds like the difference in vacuum created when putting the transmission in gear is causing some problems. My guess is the vacuum advance isn't working. Check to see if your advance weights are rusted together. They should be free to spin inside the distributor. If you have a spare distributor with a working vacuum advance (or if a buddy has one), install it and see if that fixes it. I'm guessing it has something to do with your distributor, whether the advance weights or a bad vacuum advance itself, providing all your vacuum lines are connected and not dryrotted.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-26-2011, 02:48 AM   #9
Rifter_Chevy
Re: Backfire
vac advance line is brand new as of 2 months ago when i did the carb swap, the old line was dryrotted really bad.
Might just end up dropping a new dizzy in it i know a guy with a new GM dizzy with less than 5000 miles on it i could get cheap.
Old 09-26-2011, 03:05 AM   #10
Your41Plague12
Re: Backfire
I'd try that if you can get it cheap. Never hurts!
Steve
Old 09-26-2011, 03:32 AM   #11
irishman999
irishman999's Avatar
Re: Backfire
So if its backfiring out of the exhaust its valve train problems, if it backfires out of the carb its timing. That is supposed to be the rule.
irishman999 is offline   Reply With Quote
Old 09-26-2011, 06:21 AM   #12
donut
donut's Avatar
Re: Backfire
How many miles?
Verify all of your vacuum lines and connections, (and look for any obvious vacuum leaks) I'm assuming tune is good with your prior problems. If everything still checks out, pull a valve cover and all the plugs. Rotate engine by hand both ways, see if valves move equally. ie no "lag" forward to backward.
Had an old Furd years ago, could make it backfire on demand, just hit the gas hard. (sounded like a machine gun). Digging into it, I was able to pull my timing chain off without pulling the gears. It would run fine once the slack in the chain was taken up.
Not saying this is your problem, but unless the chain and gears have been changed in the past several years... IIRC some of these also had nylon timing gears.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 09-26-2011, 09:11 AM   #13
Rifter_Chevy
Re: Backfire
Originally Posted by donut View Post
How many miles?
Thanks for the reply.
ODO reads less than 6,000 miles, was at less than 2000 miles when i bought it 9 months ago so obviosuly it has been wrapped a few times i dont know how many. PO said engine had been rebuilt when he bought it 6 years ago and he only used it in the summer to haul his camper and put less than 50,000 miles on it while he owned it but who knows if thats true.
Vac lines are all good, replaced most when i replaced the carb a while back.
I know the sound of a loose chev timing chain, when they start to stretch you can hear it when you crank as it takes up the slack on the chain as the starter starts to engage, ive herd it a few times before but my truck is not making this noise when cranking. I mean im looking for a excuse to gear drive it so it wouldnt be the end of the world i just dont think this is my issue right now but who knows.
Will advise when/if i get it home in a few hours after i look at the dizzy closer.
Old 09-26-2011, 01:19 PM   #14
CoggedBelt75
CoggedBelt75's Avatar
Re: Backfire
I chased this problem myself for a month or so. A while back I started experiencing this problem also. At first there were just minor backfires thru the exhaust. Then it wouldn't do this again for maybe a week or so. Replaced plugs and seemed fine. As time progressed, the backfiring would increase on a more consistant basis along with more intensity. Then one day it became real obvious that one , maybe two cylinders were not firing. Pulled the wires off and checked each one for resistance with a volt meter. #5 and #7 wires showed zero resistance and were totally dead. Replaced them and the problem is gone. Might not be your problem but hope it's something as simple and over looked.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 09-26-2011, 02:26 PM   #15
406 Q-ship
406 Q-ship's Avatar
Re: Backfire
Put a vacuum gauge on it at idle, if the needle jumps up and down.........flat cam or burnt valve.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 09-27-2011, 07:40 AM   #16
Rifter_Chevy
Re: Backfire
This was pretty much the issue.
Didnt sleep at all today and am back at work, yay me 36 hours no sleep with 24 hours of that being at work and the other 12 driving or mechanical time! but at least the truck is fixed.
So i got home and decided screw it i got the cash im going to replace EVERYTHING ingnition related.
Issues discovered while replacing everything:
1. Cracked spark plug, litterally in half with the electrode completly burned out of the middle of it.
2. 3 Spark plug wires with broken/corroded or otherwise not functioning terminals, was driving a 5 banger 350 lol.
3. PO wired in a kill switch to the ignition coil power WITH 22 GAUGE wire.
4. Burnt contacts on bottom of cap on 3 diff terminals
5. Very weak timing advance in dizzy, loose and worn out and needed replacing.
6. Ignition module was literally burned, as in was colored black all over.
7. firing order was not correct, like by alot, like not even 2 in the order correct.
Honestly i have no idea how the hell it ran as good as it did with that disaster of a ignition system. i honestly was stunned. It must be a miracle this thing lasted 9 months of every day driving in this condidtion.
Now its got brand new plugs, wires, whole complete brand new dizzy(MSD streetfire HEI), new coil power feed wire.
It runs great and sounds alot better to.
Thanks for helping me through this disaster guys.
Old 09-27-2011, 07:56 AM   #17
sumran
sumran's Avatar
Re: Backfire
That is quite a list. one or two of those items would be a problem. To have all of them on a running truck is amazing. It must feel like a different truck.
Randy Summers
Old 09-27-2011, 08:12 AM   #18
Rifter_Chevy
Re: Backfire
It feels brand new, way more power. Now i just need to gear drive it so it makes some noise at idle its way to quiet at idle now lol.
Old 09-27-2011, 11:31 AM   #19
RastaRobb
RastaRobb's Avatar
Re: Backfire
Sounds like you have a truck that wants to run. Now that you are giving it a fair chance, never let it go. How much money did it take to change all that out? What's next?
RastaRobb is offline   Reply With Quote
Old 09-27-2011, 08:13 PM   #20
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Backfire
Your motor, unless it's been rebuilt, had a timing chain gear with nylon on it. When the nylon starts to fall off, timing is affected. I had mine fail one morning.
Here are the pictures:
What type of carb are you using? Is the advance set to ported or full vacuum? Connect at $15 vacuum gauge to the carb. How does the needle move? Compare the results to this site. http://www.centuryperformance.com/tu...e-spg-148.html
Is your truck stock? Do you have any pictures of it? Is it a nice survivor?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 09-27-2011, 10:21 PM   #21
Rifter_Chevy
Re: Backfire
cost me $120 for the MSD streetfire HEI dizzy(included all parts, cap, rotor, coil, control module, vac advance, gasket etc)
And another $75 for the plugs and wires.
The wire to replace the ignition power wire i had on hand already, call it maybe $10 in shop supplies for the wire/connectors/heatshrink and a can of brake clean i used to clean it all up.
Next will probably be a rad support as mine is bent/cracked and welded back together as has been in a collision i guess. Which will also give me a good oppertunity to replace the timing belt with a gear drive with the rad out of the way. Will also do waterpump at that time as well as maybe a better fan.
Old 09-28-2011, 07:56 AM   #22
sumran
sumran's Avatar
Re: Backfire
Originally Posted by Rifter_Chevy View Post
Which will also give me a good oppertunity to replace the timing belt with a gear drive ...
??? You lost me at timing belt. What setup do you have and what are you planning to install?
Randy Summers
Old 09-28-2011, 11:06 AM   #23
Rifter_Chevy
Re: Backfire
should have said CHAIN was into the imports for to long.
Old 09-28-2011, 01:24 PM   #24
sumran
sumran's Avatar
Re: Backfire
That explains that. Are you going to build this to a level that needs a gear drive? I thought those were only needed if you were going high RPM, full-race.
Randy Summers
Old 09-30-2011, 02:44 PM   #25
Rifter_Chevy
Re: Backfire
im just going gear drive because from what i have been told they NEVER die on you or slip/change the timing.
Im going for bulletproof reliability.
Im building the truck for a off road toy it will eventually end with a rebuilt bottom end all forged internals and im going to slap some vortec cast iron heads on it with a moderate cam designed for low to mid rpm power.
