Old 09-21-2011, 02:48 PM   #1
Gene
Gene's Avatar
speedometer cable question
which die do I use to clean up these threads. Can't get my speedometer cable started because the threads are messed up.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 09-21-2011, 05:27 PM   #2
hayhauler71
hayhauler71's Avatar
Re: speedometer cable question
If you have to remove it to clean it up just replace it with a new one then your guaranteed it wont leak should be less than $28.00
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 09-21-2011, 05:36 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I'm pretty sure that is going to be an odd thread but don't know that for a fact.
Take the bolt out and it will slide right out then you can clean the threads up with a three cornered file. Make sure the speedo gear comes out with it.
If that doesn't work someone on the parts board should have one for a four speed.
LockDoc
Leon
Old 09-21-2011, 06:30 PM   #4
Gene
Gene's Avatar
LockDoc
This is on a transfer case is it not threaded into the case?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 09-21-2011, 08:40 PM   #5
LockDoc
LockDoc's Avatar
That is a different story...I don't have a clue. In that case I would have the Mods move it to the 4x4 forum...
LockDoc
Leon
Old 09-21-2011, 09:15 PM   #6
hayhauler71
there is a hold down bolt that you remove and that speedo bullet will slide out with the gear
Fuzzy
