Old 09-21-2011, 06:25 PM   #1
68gmc owner
Frame Swap?????
I have a 68 GMC 2WD 1/2Ton longbox and was going to do the 6 lug to 5 lug conversion on it but the prices for all the parts I need in my area would be $400 to $500 and they are not readily available, So it got me thinking, I can buy a complete running 1988 or newer GMC/Chevy 2WD 1/2Ton pick up for $1000 or less. Has anyone ever did a frame swap and just put a newer frame under there truck. I think the newer frames wheel base is 6 inches longer but I can work with that. Dont know about the width though. I can do any body mount fab work needed. Was just wounder about a frame swap. Thanks for any help.
68gmc owner is offline   Reply With Quote
Old 09-21-2011, 08:47 PM   #2
hugger6933
Re: Frame Swap?????
There is or was a guy on here that did a swap from a 2006 truck.
hugger6933 is offline   Reply With Quote
Old 09-21-2011, 09:22 PM   #3
Re: Frame Swap?????
Find a 73-87 model and pulll all the parts from it. Most will bolt onto you 68 and it is a lot less work than mounting your body on a 73-87 or 88 up frame. Both of those have longer wheelbases, so you are looking at a LOT of fab work to make it happen.
Palf70Step is online now   Reply With Quote
Old 09-22-2011, 02:35 AM   #4
dmack91
dmack91's Avatar
Re: Frame Swap?????
The later frames also have a substantial step-up (behind the cab, I believe) that has to be dealt with.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 09-22-2011, 02:57 AM   #5
Ron 586
RIP Mr Ron
Ron 586's Avatar
Re: Frame Swap?????
1. Find a donor truck (73/87) with 5 lugs and disk brakes.
2.Pull the entire front cradle and rear end from it.
3. Pull all your old front cradle and rear end.
4. Install donor parts under your truck and enjoy.
This is assuming you have the engine and tranny out and out of the way. You may have to drill a couple of holes in your frame for the new front end. It's not hard if you have the tools and area to work in. Good luck.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 09-22-2011, 09:44 AM   #6
Sammy
Re: Frame Swap?????
I faced the same on the reconstruction (for lack of a proper word) on project 'Odd Ball." Now days a 5 lug conversion for the disks and a greater wheel selection it is worth the work involved. I toyed with the idea seriously of just changing the entire cradle front end from a 71. Then ended up doing a conversion with all new parts from early classics that I needed on a killer deal instead. Yesterday I got a rear end tire to tire for the rear conversion to 5 lug. But planned on beforehand to just remove the current axles and have them redrilled and plugged for 5 lug. However a last minute :come get this before the scrap heap gets it" caused me to load the trailer up for a $50 cost. I may end up just buying new U bolts as the current ones look to be well pitted of 50 plus years of rust. Save your self some bones find a doner plenty are headed to the smelt plant $200 a ton. Shouldn't cost you more than a 100 dollar bill for both the front and rear off a donor truck which is a bit more than what they are going to get at scrap price anyway.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-22-2011, 10:56 AM   #7
CC69Rat
CC69Rat's Avatar
Re: Frame Swap?????
I have the 73+ front swap on my 68, and it worked out great. You can pick up the whole k member pretty cheap, in fact I know where one is right now you could probably get for $50 (but it's in TN of course) there are several advantages to it being the parts, rotors, etc. are cheaper and you can still find most of the parts in your local parts stores. Easy 5 lug disk swap on the cheap.
I have the HD rotors too, and I understand the suspension geometry overall is slightly upgraded compared to the original design. If I were doing one myself (I bought mine already swapped over) this is the route I'd go. Mine is off an 84.
.. just my .02
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-22-2011, 01:52 PM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Frame Swap?????
running driving 76 for $600. I used the parts I needed sold the other good parts I didn't want and scrapped the rest of it. Pretty sure I made money on my 5 lug disc brake swap.
there's a reason all of us poor guys do it this way.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-20-2012, 10:37 PM   #9
BFRO$TY
Re: Frame Swap?????
what about a '65 swb frame under a '67 swb??
BFRO$TY is offline   Reply With Quote
