09-22-2011, 08:02 AM | #1 |
Is now the time for drop spindles?
Ive had a 3/5 spring drop in my '67 for years now with drums all around. Now that I'm getting around to putting on a disc/disc setup I'm not sure if I should go with 2.5 drop spindles. The front end of my truck is all apart so now is the time to make up my mind.
I need to mention that I already have a stock set of '79 spindles blasted & painted ........ready to go on. Should I spend the money on the drop spindles or run the stock spindles/drop springs since I already have them? |
09-22-2011, 09:18 AM | #2 |
Re: Is now the time for drop spindles?
Its up to you completely. but you are right, now that it is apart now would be the best time to throw drop spindles on, if your gonna do it.
I did the rebuild front suspension last year, now I am looking for drop spindles.....oh well.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-22-2011, 12:10 PM | #3 |
Happy to be here
Absolutely! My preference is spindle first, then spring. Since you already have the springs, and the truck is apart, just do it.
09-22-2011, 12:26 PM | #4 |
I guess the reason I'm just not sure of header clearence.....those friggin hedman long tubes I have already scrape from time to time as it is now. I hate 'em but I paid good $$$ for them since they are ceramic coated. They look good, just hang down too low.
If I go lower (and I want to) my hand will be forced to change headers. I already went through a battle to find a set that would clear the factory clutch linkage rod. |
09-22-2011, 01:29 PM | #5 |
Do it. I used bad front wheel bearings in my '69 to justify discs, then drop spindles were the same price, then bags where cheaper than springs. The wife had no idea, worked awesome.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
