Old 09-22-2011, 01:28 PM   #1
crispo-71
air line size
what size air line do ya recommend i got the ss7
crispo-71 is offline   Reply With Quote
Old 09-22-2011, 01:39 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: air line size
3/8" max.
1/2" is too fast.
Keith
Convert to disc brakes.
Old 09-22-2011, 06:50 PM   #3
dznucks
dznucks's Avatar
Re: air line size
I ran 1/2" on the tank side of the valve block and 3/8" from the valve block to the bags.
dznucks is offline   Reply With Quote
Old 09-22-2011, 07:46 PM   #4
crispo-71
Re: air line size
aight cool. thanx
Old 09-25-2011, 10:15 PM   #5
Envy
Envy's Avatar
Re: air line size
does anyone run 3/8 for the front and 1/4 for the rear since theres less weight in the rear, so the lift speed would match?
Envy is offline   Reply With Quote
Old 09-26-2011, 05:24 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Re: air line size
I'm running 1/2" all around. However, my tank only has 3/8" outlets. I was scared about them being too fast, so I plumbed in flow controls. I don't know if just the 3/8" out of the tank is slowing it down or the flow controls are because with the controls wide open it's perfect in my book...Fast enough to look "cool", but still slow enough so I can control the height with ease.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-26-2011, 10:15 PM   #7
shortbed70
shortbed70's Avatar
Re: air line size
I had to slow the front down a bunch running half in all the way. Ended up using a plug and drilling a 3/16" hole in the center of it on the dump valve.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-27-2011, 03:57 PM   #8
jimmydean
jimmydean's Avatar
Re: air line size
I ran all 1/2" in my '69 and there was no stopping it from all up to all down. I installed dump and fill adjusters and was able to dial it in well.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
