Old 09-22-2011, 09:14 PM   #1
Sixxer
Sixxer's Avatar
C20 Tubular Control Arm Install Problem
Need some help from you guys... I am in the process of installing a set of tubular control arms for a c10. The problem is the lower control arm shaft mounts as a plate and the new shafts mount using U-bolts. Does anyone have measurements or know which hole to utilize and which one needs re-drilled to mount these?
Sixxer is offline   Reply With Quote
Old 09-22-2011, 11:36 PM   #2
Captainfab
60-66 Nut
Re: C20 Tubular Control Arm Install Problem
I don't happen to have the measurements you are looking for. I could probably get you some tomorrow. Keep in mind that you will also need to install the saddles that the lower control arm shafts rest in. It might be just as easy to switch the crossmember for a C10 unit, or a '67 and up C20 unit
