09-23-2011, 09:22 AM | #1 |
Pedal to booster push rod?68,C-10.
I have the booster and it's mounting bracket,but not the rod.
I don't even know what it looks like. Anybody got a picture?Goes from the pedal to the boosters linkage. Is it re-produced? Thanks,Mike. |
09-23-2011, 09:52 AM | #2 |
Active Member
Re: Pedal to booster push rod?68,C-10.
Someone posted this pic some time ago and I saved it...
09-23-2011, 12:45 PM | #3 |
Thank you!!
Exactly what I needed to see. And now-Will the rod from a 70/71 fit?(I know where one is,but it's still in the truck) Thanks,Mike. |
09-23-2011, 01:29 PM | #4 |
Active Member
Yes it should fit. If yours was a conversion from manual brakes, be sure and adjust the brake light switch afterwards.
09-23-2011, 04:39 PM | #5 |
Thanks again!
I will adjust the brake switch. The 68 was manual brakes and I got this booster with no rod. I also have the 70/71 parts truck,but the booster on it is larger diameter than the booster I have for the 68.But,it is also a disc brake 5 lug truck. For now,I can have power brakes. Mike. |
