Old 08-15-2003, 11:43 AM   #1
BobM
Steel Blazer Tank Conversion Install
Anyone done the steel Blzer tank conversion in a P/U? Looking for pictures or advise on things to look out for when doing it. Received my new tank kit yesterday.
BobM is offline   Reply With Quote
Old 08-15-2003, 01:03 PM   #2
72longbed
72longbed's Avatar
Steel Blazer Tank
Just put in the steel tank about a month ago. The main problem will be the bed support that is in the way of the tank's filler neck. If you try to mount the tank tabs in the factory frame holes it will put the filler neck right in the middle of the bed support. I bent the tabs down and slid the tank about 2" back so the filler neck is to the rear of the bed support. The only other thing is fabricating a filler location. Determine if you want to cut through the fleetside or not, if not, you can run it up through the floor of the truck behind the drivers wheel well inside the bed.
Any questions, just e-mail me. 72 longbed
philwec@fast.net
72longbed is offline   Reply With Quote
Old 08-15-2003, 04:52 PM   #3
ChevyDude
Here is a pic of a "Kick Butt" way to do the filler neck. I will be redoing mine this way!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 08-21-2003, 01:17 AM   #4
diggy
chevydude,
any instructions, parts, or special considerations on how to install that setup? it looks sweet
diggy is offline   Reply With Quote
Old 08-21-2003, 09:50 AM   #5
Yukon Jack
Yukon Jack's Avatar
Contact Tennman as that is his truck - very aweseme, here's another pic.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-21-2003, 10:27 PM   #6
Carl71
Carl71's Avatar
I seen where they were using a s-10 door, What about the filler tube , Whats it off of?? Starting this project soon?
Carl71 is offline   Reply With Quote
Old 08-25-2003, 10:51 PM   #7
truckresq
truckresq's Avatar
Best Idea I have seen
That is a very good idea, very inventive!!!!
John
Sacramento Area
1969 C10 Fleetside
truckresq is offline   Reply With Quote
Old 09-14-2003, 01:07 AM   #8
72shorty
Anybody done this to a stepside?
Douglas King
Independence, MO
72shorty is offline   Reply With Quote
Old 09-14-2003, 07:55 AM   #9
70c10
67-72 Addict!
70c10's Avatar
That does look cool. I also like the flip down tail light lense version.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-14-2003, 02:02 PM   #10
Red68
Red68's Avatar
I am in the process of installing a poly tank with the filler location just like this. Go to http://www.classicheartbeat.com/ under the How to section Wes posted the instructions along with more pictures.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 09-14-2003, 07:38 PM   #11
Carl71
Carl71's Avatar
Thanks Red, Its what I been look for.
Old 09-14-2003, 10:49 PM   #12
72MARIO
72MARIO's Avatar
Here is mine. About 60 hours involved in it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-14-2003, 10:51 PM   #13
72MARIO
72MARIO's Avatar
Filler Neck
2005 TAHOE DD
Old 01-25-2004, 03:14 PM   #14
Tim Cline
Has anyone tried using the original filler neck an plumbing it to the frame mounted tank?
67 GMC SWB Project:60 4BM 350 4SPD
67 Chevy C10 Custom LWB V8 Project
69 LWB IL6 3 on tree project
71 SWB Frame off project
72 LWB C10 Factory Tilt Project.
Tim Cline is offline   Reply With Quote
Old 01-25-2004, 03:31 PM   #15
72MARIO
72MARIO's Avatar
Why not just weld the original filler nech to the cab ?
2005 TAHOE DD
Old 01-25-2004, 03:37 PM   #16
chevymaz
What are you looking at?
chevymaz's Avatar
there is a nice write up with pics on the FAQ's section of this board
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
