#3426 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Project Vitamin C-10
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#3427 | |||
1 thing at a time is progress.
![]() Quote:
![]() Quote:
![]() Got a little bit of problem with the rear sill not letting the wood lay flat. If you remember I tested the wood with the new rear sill that I bought and ended up using the OE one. I didn't forsee this problem since I was using the OE piece. The piece on the sill where the bolt goes thru is sticking up which is pushing the wood up. I guess it was like that from the factory. I did tighten the main bolt down with no change. I walked away and finished the gauge pod from last night. I have to consider my options.
Alan
Philippians 2:14-16 |
#3428 |
spend 5 minutes with a router, another 20 with paper and sealer and call it a day!
#3429 |
Daring to be Different
Or use the BFH again.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#3430 |
![]() Join Date: May 2009
That is odd that pod should be the same height as the cross sill, curious why it's that way if it's OE....Vernski
#3431 |
I had to move mine down some.........
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#3432 | |||
Not this time. ![]() Quote:
Yours was a mar-k, right? Did you have to adjust on the pod or lower the complete sill? ELECTRICAL ?? Ran into an issue. Go figure. ![]() So what turns the light on? ![]() EDIT: I did some searching and found this Quote:
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 09-26-2011 at 11:54 PM. |
#3433 |
Never mind me, I'm just thinking outloud again. I believe I have it figured out.
Alan
#3434 |
I can't remember what alternator you are using. Do you have a one wire alternator? If so, I called American Auto Wire, and asked the same question. They said "a one wire alternator doesn't need a charge light." Go figure???
#3435 | |
YES it's OK. The idiot light will monitor alternator output and the diode is there to keep this generated voltage from feeding the coil once the key is turned off.... Keep those photos come'in, I'm more inspired with every post...!! ![]() Danny aka: 66BowTieBoy ![]()
#3436 | ||
Got bored at work and decided to sand the paint off the top of the hood. It appears to be original paint. The interesting thing is I found some black filler on the left rear corner. It was about 1/4" thick. I'm thinking it was done at the factory from damage on the assy line. Has anybody heard of this? I'm getting it blasted, but wanted to go ahead and beat out some dents. The white paint that is left on top are low spots.
Alan
#3437 |
I've thought long and hard about getting a GMC hood for my truck but mine is in perfect shape so I think I'll keep it. I love the more aggressive look of this one. What truck is it going on?
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#3438 | |
I finished up the last gauge pod QD's. Chasing more wires tonight. I discovered last night that I will have to make a parking brake switch bracket. Did these trucks not have a bracket/switch? If so maybe it's in the shop some where. Shannon came thru for me and got a 1/2" SS tube so I can run the altenator wires in. Still have to mount it. Thanks buddy!!
Alan
#3439 |
Sir,
It has taken me a week and a half of reading every post to get here, and all I can say is wow... I am not only grateful of your detailed posts, but inspired as well. Thank you. If I can figure out a way to post pics here I will do a thread like this on my 66 stepside project, otherwise I am keeping my Facebook and my CarDomain sites up to date. Thanks again for making such a great teaching thread!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#3440 | |
The quickest way to post a pic is to use the manage attachments a little ways down from the text box where you write your message. Go to this link for better explaination. I have been using this a lot lately. You can't type text between the pics. Also you can only post 5 pics per message. You can also use the gallery in the blue bar along the top of the page. It's a little harder to use. If you use that copy and paste "IMG" code of the pics that you have uploaded into your message. I have used an offsite image host such as photobucket.com. There are others out there. Using one of these sites you also copy and paste the "img" code into your message. Anytime you copy and paste an img code you can write between the pics. Your also able to post 10 pics per message. But smilies take away from that number. If you have 2 smilies then you can only post 8 pics. Hope this helps.
Alan
#3441 |
Alan
I also have been following your thread for months.. just joined a few days ago.. I don't have the modern truck as you do. I have a 57 stepside short bed.. I've added 396, 700R4, complete wiring kit from EZ Wire( very good kit) VDO Gauges, Power Windows (Specialy windows), Front end with rack and Pinon stering from a 95 Dodge Dakota, Stering Column from a 92 Caprice,. Was painted when I got it, 15 years ago. now has dings and dents.. character I quess... recently did a complete custom interior except the seats. Still need to do the bed.. I have wood that my dad and I cut down on the farm before he passed away, IN 89. I will use this cherry for the bed some time.. LOL Still need to sort out the rear end... I was told it was from a late 70s camaro.. Ii is a 10 bolt 8.5 I think.. never had to cover off to vertify.. gears is pretty low maybe 3:08 or somewhere near that as 70 MPH on the interstate is 1400 RPM.. in overdrive.. >75 overdrive installed by a friend of mine when he went throught the tranny 10 years ago.. Keep up the great post You inspire all you find you.. |
#3442 | |
![]() I have almost got the gauges done. Need to do the speedo pod in the center on the truck side and finish up the brown wire on the "GEN" light once I get the SS tube mounted to the engine for the altenator wires. Also spent some more quality time bumping dents on the hood.
Alan
#3443 |
Well I really like the dash you installed... I've seen that done a couple of times and it always adds a real custom touch.. I will try to get the link up in a few days.. I am real busy now and don't have much time extra.. LOL Only get to work on the 57 every so often..
#3444 |
a couple of photos of my therapy/
#3445 |
Very nice truckguy.
Got the rear LED lights done....almost. Just need to clean it up a little. The right side did just fine. It took me forever to get the left side to ground, but I got it. I also used a QD for the lights just in case the bed has to come off. I still need a ground strap for the bed. I was just using an extra battery to power the lights. I haven't powered up the complete truck just yet.
Alan
#3446 |
Well I see you went to the "extreme" of buying all your weatherpak connectors.. LOL I visted my local yards and pulled a couple of hundred from Gm cars and trucks.. Found everthing I needed and then got on the internet and purchased the correct connectors to go in them... Saved a buch of money and gave me some special connectors such as 6pin connector from a Cadallic from the mid 80's. I put in a kit from EZwire.. they have a great diagram and easy to follow instructions. Great job on your truck, as I've said before your inspire all who find you..
#3447 |
just curious, did you have to scrape off some paint to get the light to ground. I had to run a special ground wire as my lights are in a fiberglass roll pan.. you will appreciate this.. when I was doing the headlights. I reversed the ground and low beam connecting in the socket and when I turned on the headlights and turned on the 4 way flashers the dash lights flashed. I almost fell out of the truck I was laughing so hard... LOL Called the hot line at easy wire and he knew what I had done right a way.. 5 minute fix 6 months to figure it out..
#3448 | ||
I went the lazy way and just clicked "buy". ![]() Quote:
That's funny, now that you figured it out. I wonder what gremlins I will have when I power every thing up. TIP: I discovered this today, maybe ya'll already know. I was trying to get a string run thru some tubing so I could pull some wires. It wasn't going very well. I blew air thru the tube while feeding the sting and it worked nicely. It took one good blast of about a second. I got the tubing in for the tail lights and fuel tank and rerouted the headlights, radiator fan and horn. Also got the gauges mounted for the final time (I hope). Still have to wire the park brake light.
Alan
#3449 |
Nice progress Alan. Won't be long now. I bet you can't wait.
#3450 |
1 more
Alan
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
