09-24-2011, 11:39 PM | #1 |
sway bar question
greetings all, I'm new to the board and a new owner of a nice 67 shortbed pickup, My first question : the truck is lowered and needs a front sway bar, I read somewhere that the bar is different for a truck with stock height and a lowered one but can't find it now. is there a different sway bar for a stock one and one with dropped spindles ? thanks in advance for any help or info..
09-30-2011, 12:00 PM | #2 |
Re: sway bar question
I remember the thread but i can't find it either, but i do rember that the bar for a lowered truck was attached directly to the frame instead of the stands to help with ground clearence.
Used an after market one on mine and it works great.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
09-30-2011, 12:58 PM | #3 |
needs more $$$
Best sway bar write up ever: http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Depending on how low you are, you can do like chopnchaneled said by omitting the stands and mount it directly to the frame.
1970 2wd Blazer |
09-30-2011, 01:03 PM | #4 |
Exact same sway bar for stock height and lowered. As mentioned above if pretty low simply remove the frame brackets and bolt directly to the frame and you are good to go!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-30-2011, 01:44 PM | #5 |
thanks guys, that's just what I was looking for
09-30-2011, 02:16 PM | #6 |
Junior Member
Bolt directly to the frame - no bracket. That's what I'm doing then. Great tip. Thanks!
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
09-30-2011, 03:31 PM | #7 |
Location: North Cal and no Sac or Bay area is not NORTH
Great write up for future ref.
Never argue with an idiot, they will bring you to their level and beat you with experience.. |
