Old 09-25-2011, 09:39 AM   #1
trev1
Exclamation Clutch & Z Bar Linkage
HELP!!!! Im in the middle of hookin up the clutch linkage, and am havin a heck of a time. I went to the junk yard and got the Z-bar and linkage from the clutch pedal. The trans has the old style clutch fork. I took and made the the z-bar attachment that bolts onto the frame with a piece of angle stock. All that turned out great. The problems now start. I tried to hook up the clutch linkage from the pedal and it wont reach the Z-bar. The angle is too great. So I took a piece of flat stock, drilled two holes in it and attached one end to the clutch linkage and the other I took a grade 8 bolt and made the stud to attach to the Z-bar. The fulcrum is wrong.
What I need is someone to send me a pic showing how the Z-Bar is attached to the clutch linkage. It is greatly appreciated.
Its a 69 chevy cst 350 v8 with NP833 4sp OD tranny.
trev1 is offline   Reply With Quote
Old 09-25-2011, 03:03 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Clutch & Z Bar Linkage
I don't have a picture myself, but I use the LMC catalog a lot to see how things go together.
Hopefully some one will post a picture for you soon.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-25-2011, 04:49 PM   #3
trev1
Thanks ShyGuy! I figured it out. The Adjustment rod for the clutch fork was too short. I made a longer one and the clutch releases now. I had enough throw on the clutch pedal. I still have enough adjustment to go more if I need to.
Old 09-25-2011, 05:40 PM   #4
treveiger
treveiger's Avatar
This may be stupid but did you adjust the rod out all the way, is the fork hooked up to the z rod. What year is the clutch system
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-25-2011, 06:08 PM   #5
vectorit
What?
vectorit's Avatar
Here is a pic of the on in my 68.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
