Old 09-26-2011, 04:36 PM   #1
Urban Suburban
Question 6.2 service engine soon - no codes????
Like the title says... my service engine soon light has been coming on and going out for a week or so. It cam on for the first time just before i lost the rear brakes. I figured they were related. brakes have been fixed and the truck scanned... No codes came up. The light came on a few times over the weekend. The last time I tapped the dash to be a smart ass and the light went out. I guess I need to make sure it didn't burn out or something. anyone have any thoughts. I was told that the 6.2 Diesels don't really use much of the computer... is this true?
Urban Suburban is offline   Reply With Quote
Old 09-27-2011, 02:46 PM   #2
Re: 6.2 service engine soon - no codes????
Yes,6.2s don't use the computer. Maybe the light is acting up or something with the hydro-boost?
Old 09-27-2011, 04:59 PM   #3
Urban Suburban
Interesting... Any idea how the hydraboost fits in?
Old 09-30-2011, 02:32 PM   #4
hatzie
Moderator
hatzie's Avatar
It doesn't.
The computer doesn't do much on the diesel applications. The TCC engagement is about the only useful function. Glow Inhibit, and HPCA can be run with relays and a temp sensor. EGR can be run on vacuum controls.
According to the 1989 R/V schematics
The LH6 Diesel ECM Outputs;
  1. EGR
  2. HPCA Housing Pressure Cold Advance
  3. Glow Plug Inhibit
  4. TCC Torque Convertor Clutch
The LH6 Diesel ECM Inputs;
  1. MAP sensor
  2. ESS Engine Speed Sensor [on top of the vacuum pump]
  3. VSS Vehicle Speed Sensor
  4. Brake pedal engagement switch
  5. TPS Throttle Position Sensor
  6. Coolant Temp Switch
Old 09-30-2011, 02:36 PM   #5
Urban Suburban
interesting... we have scanned it an no codes with two different mechanics and computers???? will have to see whats the deal. I did notice that it looks like there is some glue where someone tried hiding it with tape at some point
Old 09-30-2011, 05:04 PM   #6
hatzie
Moderator
hatzie's Avatar
Read the codes the old fashioned way. http://www.obd-codes.com/faq/read-gm...codes-free.php
Old 10-06-2011, 01:29 PM   #7
Urban Suburban
so i had a broken glow plug and two broken glow plug connectors. The bulb is defiantly burnt out now but still smokes a lot and runs ruff on a cold start
Old 10-06-2011, 07:30 PM   #8
Goldfinger
Goldfinger's Avatar
the service engine soon really only looks for shorts
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
