09-27-2011, 09:16 PM | #1 |
Best frame paint?
Going to paint the frame before long and was wondering about really good paint. Not interested in Rustoleum or spray bombs (been down that road and they do NOT work in South Texas humidity and rain). POR 15 has never worked well for me on sandblasted metal like the frame will be. Even with their "new metal treatment" it always seems to peel off in spots. (and yes I follow instructions religiously on paint products and know the necessary things to do on POR 15). Any suggestions? Have not ruled out powder coating but would like to paint if possible
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
09-27-2011, 11:46 PM | #2 |
SWB 4x4 Collector
Re: Best frame paint?
Believe it or not, I am a big believe in getting Tractor/Industrial Paint and hardner from a place like Tractor Supply. You can get it in Semi/Gloss Black or other colors. Stuff seems pretty dang tough as I have used it on frames in the past. The first restoration of my 71' I used POR 15 with all the required steps and it peeled bad. I sandblast my frames now and spray what Tractor Supply has on the shelf $20-30. Just some Oil Enamel Primer, and spray color mixed with Hardner. Has held up better than POR15 for me. We have bad humidity in KS too. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
09-28-2011, 07:21 AM | #3 |
I've posted it before, its a great paint called Hammerite.
Here:http://www.tcpglobal.com/autobodydep...FRM6gwodnXY_ww If you plan to spray it with a gun I use Acetone to thin it. |
09-28-2011, 04:25 PM | #4 |
It WOULD make sense that an industrial coating like something from TSC would work, after all tractors and equipment are always outside and work harder than most of our trucks ever will. Hmm I will sure think about doing that.
10-01-2011, 12:06 PM | #5 | |
10-01-2011, 06:20 PM | #6 |
Is that Hammerite ok to use over sandblasted metal? And there is no primer? How does it hold up? Also I plan on spraying with a gun, Is one quart enough or would a SWB frame require 2?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! Last edited by El Campo; 10-01-2011 at 09:30 PM. |
10-02-2011, 08:57 AM | #7 |
we spray it right over blasted metal .I would get at least two quarts
10-04-2011, 09:39 PM | #8 | |
Just a Member
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
01-19-2014, 06:27 PM | #9 |
Digging up an old thread here....
El campo how did you end up painting the frame and how did it hold up? Looks like it's been almost 3 years. I'm looking to do the same thing now. Also, is this the same product? http://www.kilz.com/hammerite/v/inde...008a05d103RCRD
1977 Chevy K20 1959 Chevy Apache 3200 |
01-20-2014, 05:01 AM | #10 |
Yes it is.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
01-20-2014, 11:37 AM | #11 |
I am going to do a frame with the tractor paint,they have no primer do I use primer.I have some Rustoleum industrial primer is that OK to use
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
01-20-2014, 12:40 PM | #12 |
ppg (and others) makes an industrial epoxy primer that is reasonably priced.
called " commercial performance coatings" primer # epx-908 they also have a compatible enamel top coat |
01-24-2014, 05:29 PM | #13 |
So what paint did you end up using on the frame?
