Old 09-28-2011, 10:38 PM   #1
awbrown
383 LS dyno test
Finished a 383 LS series engine last week and dynoed it .. The customer wanted 500hp ,which is really plenty for the street being that the customer has never had more than 300hp..
Here is how the build was..
GM #243 heads cnc ported from Wegner automotive (nascar west series motor)
11.3 comp.. Diamond Flat top pistons
224@.050 intake 234 @ .050 exhaust .588 lift straight accross
Scat 4" stroke crank
Scat 6.125 H beam rods
stock 5.7 aluminum block
stock LS6 intake
stock throttle body
accell injectors
stock rockers
beahive springs
516hp @6000 503 ftlbs torque...
It was pulling 1.0 vaccum on the top end so it could use a bigger intake / throttle body and pick up some more....
awbrown is offline   Reply With Quote
Old 09-28-2011, 10:39 PM   #2
ChrisDollins
ChrisDollins's Avatar
Re: 383 LS dyno test
Where's the video??? Lol. Sounds like a good setup.
Chris
ChrisDollins is offline   Reply With Quote
Old 09-28-2011, 10:43 PM   #3
awbrown
I wish , I may be able to post the dyno sheets , though I already delivered it to the customer....
Old 09-28-2011, 10:47 PM   #4
gearheads78
gearheads78's Avatar
Looks like a great combo. I would suggest at least sending the rockers to Harland Sharp for a bearing conversion they offer. You are begging for a stock rocker failure at your HP level. His truck should fly. My old 347ls motor made 408 to the tires with an unlocked 4000 stall and was good for 11.0's in a 3600 lb car on drag radials
i
gearheads78 is offline   Reply With Quote
Old 09-29-2011, 08:22 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
LS engines are incredible. I've played with Chevy engines for decades, and I have never seen an engine like the LS that can make major horsepower gains with very simple bolt-ons and mostly stock parts. The team that engineered that engine definitely did their homework.
There's definitely more left in that 383. Change the intake, bigger throttle body, and a cam change will get even more horsepower. That 383 is a great example of what I was talking about above. That would be a fun engine in a street car.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-29-2011, 09:47 AM   #6
lucifer
lucifer's Avatar
Cool Re: 383 LS dyno test
For sure the LS series engines rock. I dynoed a stock out of the crate LS3 with stock exhaust and air box.
This thing made 464 hp right out of the box and it was under 7K to buy.
Nice stuff!!
regards
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 09-29-2011, 08:31 PM   #7
rideblue00
rideblue00's Avatar
shooo, 7k is alot. Although my 350 cost 3500. and i only got 300hp.
rideblue00 is offline   Reply With Quote
Old 09-30-2011, 11:43 AM   #8
Scot_Douglas
Scot_Douglas's Avatar
Sweet!
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 09-30-2011, 12:33 PM   #9
awbrown
i
Actually I think they aready had that , they came with the heads from Wegner .......
Old 09-30-2011, 12:39 PM   #10
awbrown
Nice stuff!!
regards
The customer had the block ,cam ,lifters ,intake oilpan,and injectors. I supplied the rotating assembly ,heads, gaskets coil packs ,bolts, pushrods,and rockers.. Machine work and assembly it all came up to 5570.00 plus 660 for dyno time plus oil ,plugs and gas..
Old 10-01-2011, 09:26 AM   #11
pharmd
pharmd's Avatar
What intake/TB are they running? I'd ditch the HS rockers period...too many horror stories with those, and modding them just means you have more money in a rocker with a poor reputation. stock rockers do a pretty good job actually, if you want rollers, then I think most folks are just doing the comp trunion upgrade on the stockers...Yella Terra would be my preference for an affordable standard roller.
2007 TBSS 418ci AI CNC 243, Futral cam, ARH headers, RPM VI tranny, Vig 2800, 430awhp/426awtq 12.1 @110
2002 Camaro SS 346ci Heads/Cam/Intake ARH headers M6, Koni, UMI, magnaflow, DMH, Meizere, ATI, 456rwhp/414rwtq
1965 Chevy C-10 Stepside, 355, TH350, 3000 coan stall, 4.10...Going under the knive!
http://www.hubgarage.com/mygarage/profile/28922
pharmd is offline   Reply With Quote
Old 10-01-2011, 11:20 AM   #12
OJ1988
Just a car guy
OJ1988's Avatar
First post said stock LS6 intake
stock throttle body
stock rockers.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
