Old 09-26-2011, 08:04 PM   #1
62low72High
62low72High's Avatar
P1345 code
My 2000 Tahoe (old body) is throwing a code for a cam sensor. Upon initial start up the motor make noise similar to valves of lifters and after 30-60 seconds goes quiet. What is my fix for this issue? Oh 5.7 with 135k. Does not smoke. Thanks for any suggestions.
62low72High is offline   Reply With Quote
Old 09-29-2011, 04:05 PM   #2
62low72High
Re: P1345 code
Just to add to this , my service engine soon light comes on with the initial startup and after driving it for awhile the truck clears the light after 2 more startups.
Old 09-29-2011, 04:43 PM   #3
truckdude239
truckdude239's Avatar
Re: P1345 code
Okay with that code it is a ckp/cmp sensor correlation issuse, could be anything from a bad timing chain to a bad distributor. Or a bad crank sensor. Has the distributor been taken out recently? The cam sensor on that motor is in the distributor, pull the cap off and see if there is an play int eh distributor shaft
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-29-2011, 04:47 PM   #4
truckdude239
Re: P1345 code
Was doing more reading AN intermittent issuse May be cau8sed by a poor Connection,Rubbed though wire insulation or a broken wire inside the wire insulation
David fuller
2000 Tahoe 5.3l 378
Old 09-29-2011, 05:13 PM   #5
62low72High
Re: P1345 code
Has a new cap/wires/plugs from 20k miles ago. All GM parts.
