Old 09-29-2011, 09:12 PM   #1
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Kingpins discontinued for my Dana 60????!!!
So I tried buying kingpins for my Squarebody Crewcab 4x4 with a Dana 60. The truck is a 1990 Chev V3500.
I dropped by my local family owned parts supplier and was told that they didn't carry them. So I went to Napa who told me the same thing. So I call a GM dealer who called it a "socket" and said it was discontinued. So I called Partsource who also didn't carry them.
So I went to NAPAONLINE.COM and only found a kingpin BUSHING kit, https://www.napaonline.com/Catalog/R...+50014+2014047
I've never done kingpins before, is it common to only need the bushing?
Am I asking for the wrong thing? Are these considered to be ball joints?
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 09-29-2011, 09:18 PM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Kingpins discontinued for my Dana 60????!!!
No, they're certainly called kingpins. However, some do mistakenly call them ball joints.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 09-29-2011, 09:26 PM   #3
TheWhiteElephant
God is good!
Do you have part numbers? I tried Rockauto.com and they have the same bushing kit. It is under "steering" as opposed to "suspension".
Mando
Old 09-29-2011, 09:27 PM   #4
b454rat
Go to Fleet Pride, that is where I got all my 60 stuff....
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 09-29-2011, 09:28 PM   #5
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Ok thanks.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-29-2011, 09:37 PM   #6
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Ok cool. So I checked out the site. Now I'm wondering if it's the knuckle bearing or the bushing or both that I need, or if there's still something missing. It's kinda hard to tell without a pic of the part. Maybe I can find a diagram somewhere.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-29-2011, 09:38 PM   #7
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
I clicked on kingpin in the index, and it gave me parts for a tractor trailer 5th wheel.. haha
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-29-2011, 09:39 PM   #8
TheWhiteElephant
God is good!
Here are a few links, hopefully they help...
http://compare.ebay.com/like/2304918...=sbar&_lwgsi=y
http://www.riversidegear.com/dana-60...odge-ford.html
http://www.pirate4x4.com/tech/billav...pin/index.html
Mando
Old 09-29-2011, 09:40 PM   #9
TheWhiteElephant
God is good!
Looky here...
Mando
Old 09-29-2011, 09:41 PM   #10
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Edit: so I guess there where pics of the bearing. I'm guessing there's more to that to fix the major amount of play that I have in both the upper and lower kingpins..
Oh, and I forgot to get a part number from any of the parts guys today.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-29-2011, 09:50 PM   #11
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
SWEET Awesome links! Thanks, that will help alot. Do I have to pull the axle to get them out???
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-29-2011, 09:59 PM   #12
TheWhiteElephant
God is good!
I've never done a Dana 60, but yes, you will need access to them with the axles removed, but I wouldn't sweat that. It will give you an opportunity to replace the inner axle seals, which you had BETTER do at the same time.
Now is a good time to go through all the seals and bearings.
Mando
Old 09-29-2011, 10:01 PM   #13
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Gotta love a snowball project!! haha Thanks for the advise. I'll do it all while I have it apart.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-29-2011, 11:46 PM   #14
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
OK man, i just did mine, check it out. It is VERY common only to need the bushing in the top and not the whole Kingpin. You do not have to remove the axles, or even the brakes to do the top. Just take the 4 bolts out of the cap and remove the white bushing. SUPER simple. I did replace the Kingpin while I had mine apart because, well, i figured might as well. You will need a big ass 7/8 allen wrench to remove the kingpin itself. i have one you can borrow if you pay shipping. But theyre not too expensive. I used the 7/8 allen wrench and a jack handle cheater bar. The bottom has a bearing, not a kingpin. You can remove the lower cap, replace the bearing and reinstall. You dont NEED to replace the race unless its rough, pitted, etc... but again, I figured might as well.
I got my kingpin rebuild kits from Off Road Design.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-29-2011, 11:57 PM   #15
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Very good info, thank you very much! I'll see if I can find a 7/8 allen locally, but thanks for the offer.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-30-2011, 04:37 AM   #16
my4by2
my4by2's Avatar
Try these: http://www.wfoconcepts.com/pr/Dana-6...3164/3172/3435
They're from WFO Concepts - the shop building my truck. Should work for ya!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 09-30-2011, 09:33 AM   #17
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Cool thanks! I'll use them if I can't find any locally.. Still going to dig around town a little more.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 09-30-2011, 03:41 PM   #18
STOCKISH
STOCKISH's Avatar
I was looking at my recepits last night, I actually got mine from WFO as well. Same brand and all.
--Josh
Old 09-30-2011, 04:15 PM   #19
Dunenutt
Newbee
Dunenutt's Avatar
More often than not, you are going to need a torch to heat up the C that it threads into. They can be REALLY stuck in there!
Dunenutt is offline   Reply With Quote
Old 10-02-2011, 11:11 AM   #20
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
I'll keep that in mind. I went back to the GM dealer since they said they had the lower bearing, but not the kingpin. So I go there and they say, yup, it's $172 for just the lower bearing, and oh nevermind, it's discontinued too.. So I go back to Partsource who also said they only had the lower bearing but not the kingpin when I talked to them on the phone, and when I got there, I was watching the computer as the guy looked up the part and saw a listing for the kingpin also! So it supposedly came in last night, I'm going to pick them up later today and see if it's the right stuff.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 10-02-2011, 01:44 PM   #21
Mr. 250r
Mr. 250r's Avatar
The dealerships around here have no clue what kingpins are and really don't know much of anything lol unless you get exact part #'s they are useless as for the rebuild ill eventually be getting mine from here https://www.4wdfactory.com/store/cat...in-Front-Parts if you go to the rebuild kit they also offer the allen key to take the kingpins out of a socket but you'll need one heck of an impact to get it out
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 10-02-2011, 09:15 PM   #22
STOCKISH
STOCKISH's Avatar
I used a 2 foot long allen wrench and a 6 foot cheater pipe! No torch needed here. I've done tons of them. Just crazy strong I guess! LOL!
--Josh
Old 10-08-2011, 11:30 AM   #23
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Ok, me and my little bro ripped it all apart and found that the lower bearing was fine. The reason there was so much play in the lower bearing was because the kingpin bushing had enough play to let the spindle drop when I jacked up the axle to check for play. When you let it off the jack, the weight goes back on the lower bearing and it sits where it's supposed to, and the play is at the top in the kingpin bushing.
The kingpin bushing was in about five pieces, but the kingpin was totally fine with no scoring on it. My axle seal was fine, as were my U-joints, so we just replaced the plastic kingpin bushing, cleaned up the lower bearing and replaced the axle/hub bearing while we were in there. Thanks again for all your help guys!
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 10-08-2011, 01:00 PM   #24
joe231
joe231's Avatar
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 10-08-2011, 10:39 PM   #25
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Originally Posted by joe231 View Post
Sorry, my hands were too dirty for the camera! lol.. The links that were given have lots of pics..
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
chev, dana60, king, kingpin, pin
