Old 09-30-2011, 09:11 AM   #1
crazeetxn
crazeetxn's Avatar
Brake Rotor Size
So I need to replace the warped rotors on my '86. Local parts stores match it according to back brake size. I'm using the opportunity to upgrade to the drilled/slotted rotors. Found these but it just says fits rotors that are 1.25".
http://www.summitracing.com/parts/SUM-DSEP-5516R/
How the heck am I supposed to know if they'll fit AND what's it really matter about the back brake size? I'm sure it does, just got my curiosity peaked.
Thanks for the advice...
Troy
crazeetxn is offline   Reply With Quote
Old 09-30-2011, 07:49 PM   #2
karl
karl's Avatar
Re: Brake Rotor Size
Back brake size? What does your truck have for rotors? 1" or 1.25"? Measure thickness of rotor. If you change the rotor size you will have to change other parts also.
karl is offline   Reply With Quote
Old 09-30-2011, 08:40 PM   #3
TheApocalyptican
TheApocalyptican's Avatar
Could be wrong but, I thought that the idea behind knowing the back brake size was that the bigger back brakes come with the bendix front instead of the delco front brakes.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
