Old 10-02-2011, 11:28 AM   #1
Thadious
S10 Swap Headers
Has anyone ever tried using these headers on a mild 350 swap build on an S10 chassis?
Cheers!
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 10-02-2011, 12:54 PM   #2
Lrall
Lrall's Avatar
Re: S10 Swap Headers
They would guaranteed not work on my s10 swap. Stock or custom are the only ones that will work that I know of
Lrall is offline   Reply With Quote
Old 10-02-2011, 02:33 PM   #3
Coupeguy2001
Coupeguy2001's Avatar
Those curiously look like the 70-74 chevelle cast iron ones
Coupeguy2001 is offline   Reply With Quote
Old 10-02-2011, 02:34 PM   #4
Thadious
Just looking at the side profile... I have about 3 1/2" between the head and the intermediate shaft and looking for something, other than a cast iron head that will flow reasonably well. I know that chev used a tubular exhaust manifold on some of their 85-88 trucks and vans... this just looked like it would be narrow enough to fit, yet still allow space for the plug wires...
Ted.
Old 10-02-2011, 03:24 PM   #5
Coupeguy2001
Chevy used some tubular ones on the corvettes as well. When I had the original steering in my 57, I used the corvette ex. mans and I had a machine shop angle mill the gasket flange 1/8", and it tucked the header away from the steering box.
Maybe you could weld on a thicker flange and angle mill it back down for clearance so it hugged the block a bit more on an angle. You could even angle mill it so it was thinner at the front than the rear? Then reweld if you took too much off for ridgidity.
or vice versa.
Old 10-04-2011, 04:20 PM   #6
D-man313
D-man313's Avatar
Yes i used those one my 49 s10 swap, with 350/350. bolt right on and fit great inside the fender wells.
D-man313 is offline   Reply With Quote
Old 10-10-2011, 04:18 PM   #7
texas56
texas56's Avatar
Those look pretty cool! we ended up modifying one tube on a set of 67-90 camaro headers on ours but those there look better to me
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 11-03-2011, 01:02 AM   #8
blitz'd
vintage car junkie
blitz'd's Avatar
Have any pics of them on the truck? Where are you guys finding these?
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 11-03-2011, 01:06 AM   #9
Thadious
I've decided to custom build a set. So not like me, I know, but just gathering the materials now. Have all mandrel bent primaries to weld up, now just have to waterjet cut the flange and fab a set of collectors.
I'll be mocking up a set on the truck out of PVC and ABS to figure placement and lengths, but after that it will be stainless 1 1/2" primaries to a 2 1/4" set of true duals.
Old 11-03-2011, 04:23 PM   #10
D-man313
D-man313's Avatar
Heres a few. I found mine on craigslist but, heres some
http://www.advanceadapters.com/products/pn-717053/
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
