Old 08-16-2003, 11:48 PM   #1
lngbed71
Nothing fits but the oil
lngbed71's Avatar
This stinks.....
I have the most stinkiest of gas fumes in side the cab when I'm driving. It's bad. I'm glad I don't smoke or there would be great mushroom clouds of doom everywhere I go.
I see no signs of leakage outside or inside the truck, and I have replaced the rubber lines from the tank to the frame. Jeeeez this stinks, has anyone else had this problem? and what was done to stop the stink.......thanks.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 08-16-2003, 11:50 PM   #2
jimfulco
Check the fuel filler hose
jimfulco is offline   Reply With Quote
Old 08-17-2003, 12:03 AM   #3
lngbed71
lngbed71's Avatar
Thanks, is it tough to replace?
Land of the free
Old 08-17-2003, 12:14 AM   #4
70c10
67-72 Addict!
70c10's Avatar
The rubber o-ring is probably worn out at the top of the tank. Don't fill it all the way until you replace/check this.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-17-2003, 12:22 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Another spot to check is the sending unit "O" ring, and the little seal on the stud that your sending wire is attached to. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-17-2003, 12:25 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Being a 71, there is also a hose that loops around from the tank back to the tank (Not sure what it is supposed to do) inbetween the inner and outer wall on the passenger side beside the rear window.
Check to see that it is still in one piece.
Old 08-17-2003, 09:54 AM   #7
lngbed71
lngbed71's Avatar
I'll check out all of the above, thanks.
Land of the free
Old 08-17-2003, 09:57 PM   #8
big blue 72
Hey andy, that is where the leak was on the 71 i am building for my wifey!. i just cut it off and it seems to work fine.....till i started the frame off.
virgil
what is that thing anyway?
big blue 72 is offline   Reply With Quote
Old 08-17-2003, 11:45 PM   #9
SLS
Finish the'71..or bust!
SLS's Avatar
EECS
EECS Evaporative Emission Control System
On my '71 350 that 'extra' tube leading out of the gas tank is for vent fuel vapors out of the tank...and the tube goes to the charcoal canister in the engine compartment. Maybe this is it??
According to my Haynes manual:
"An indication that the system is not operating properly is a strong fuel odor."
Check that the rubber tube is not blocked or the canister is not stopped up.
SLS is offline   Reply With Quote
Old 08-17-2003, 11:49 PM   #10
lngbed71
lngbed71's Avatar
There is one line headed out of the tank to the front of the engine bay. The fumes are almost as if you pour fresh gas right from a can onto the floor in the cab. I'm checking the stuff inside the cab first.
Land of the free
Old 08-17-2003, 11:49 PM   #11
Longhorn Man
Well, I have never messed with one myself, but in the LMC catalog, it just shows it looping in the cab...
I have no idea what it would be...onless SLS is right.
