Old 10-02-2011, 10:39 PM   #251
big_al_71
big_al_71's Avatar
Re: The Fuse is Lit...
Originally Posted by RocketKing View Post
Thanks for the kind words! I finally got most off the harness back together and I am in the process of getting everything hooked back up (pics coming). Tell your buddy if he needs any help not to hesitate to ask.
Ok will Do thanks!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-03-2011, 11:02 PM   #252
RocketKing
RocketKing's Avatar
Got the harness back on...well mostly. I have more plugs than plug ins. The harness was already off when I got the motor so it is taking a little time to try and figure where things go back on.
I haven't finished wrapping up the whole harness yet, I am still looking at where I want to mount the PCM. I thought about running it through the clutch rod hole and then getting a new rubber grommet and feeding the wires through. Between the grommet and the engine covers it should hide most of it.
If I can get it to look good then it would allow me to fab a bracket and mount the PCM here
If I can't make it work then I will look at the core support instead.
Rex
RocketKing is offline   Reply With Quote
Old 10-04-2011, 12:30 AM   #253
67chevy1series
67chevy1series's Avatar
you should change your name from rocket king to master electrician! lol im getting good at wiring my 67 in a good way not a "damn PO!" way lol but this looks tuff.
67chevy1series is offline   Reply With Quote
Old 10-04-2011, 10:08 AM   #254
RocketKing
RocketKing's Avatar
I will be glad to get everything wrapped back up and tucked away, just looks so bad with wires hanging everywhere. But, that may take a little while to do.
Rex
Old 10-04-2011, 11:43 PM   #255
67chevy1series
good luck, i hope it goes and flows!
Old 10-19-2011, 04:09 PM   #256
nobull2
nobull2's Avatar
looks great, who did the paint
nobull2 is offline   Reply With Quote
Old 10-19-2011, 07:21 PM   #257
mcbassin
Still Learning
mcbassin's Avatar
Rex, The wiring looks good to me. You have any pics of how you routed that fuel line up to the intake? thanks. Keep up all that hard work.
Old 10-19-2011, 10:57 PM   #258
RocketKing
RocketKing's Avatar
Hey Alpena! Glad to see someone local. The paint is being done by Roger Morrow in Green Forest
Rex
Old 10-20-2011, 08:45 AM   #259
nobull2
nobull2's Avatar
he does nice work, I have stop and talked to him once before.
Old 10-20-2011, 02:10 PM   #260
RocketKing
RocketKing's Avatar
Is this what you are looking for Mike?
Rex
Old 10-20-2011, 02:33 PM   #261
mcbassin
Still Learning
mcbassin's Avatar
Yep, that's what I was looking for. I have already ran mine down the passenger side. I'm not sure how to route it just yet? thanks for the pics.
Old 10-20-2011, 09:58 PM   #262
RocketKing
RocketKing's Avatar
Mcbassin and I were talking about different connectors on our harnesses. I thought I would post some pics of what connectors I had and where they went. Most people probably know where the plugs go but when you get a harness that is not on the engine it can make you scratch your head just where everything goes. Hope this help someone.
This plug goes to the connector that is right above the starter. (Crankshaft Sensor)
MAF sensor, does not go on the engine but on the air intake by the filter
Rex
Old 10-20-2011, 10:35 PM   #263
heeroyue2002
fat old dude
heeroyue2002's Avatar
how come your engine and tranny are all clean and nice but the driveshaft/driveline is all rusty
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 10-20-2011, 10:37 PM   #264
mcbassin
Still Learning
mcbassin's Avatar
Man Rex that is awesome! Thanks for the pics. That will definetly help me when I get back on mine. I will just print the pics. I have figured out a bunch of them still have a few wires without connectors though. Nice job pulling the motor they only cut a few wires
Old 10-20-2011, 10:40 PM   #265
big_al_71
big_al_71's Avatar
Man thats alot of wiring I do not have the patience to do wiring and you guys make it look so easy.....keep the picts coming
Old 10-20-2011, 11:04 PM   #266
RocketKing
RocketKing's Avatar
The driveshaft is one we found at my buddy's shop, I have no idea what it even came out of. I still need to replace the rear u joint and paint it up.
I hope it helps Mike, thankfully most of the wires were intact because it is hard enough the way it is!!!
Looks can be deceiving
Rex
Old 10-21-2011, 11:59 AM   #267
68 Four on the Floor
68 Four on the Floor's Avatar
This build looks amazing. Making me consider going ls1 in my 68.
68 Four on the Floor is offline   Reply With Quote
Old 10-21-2011, 12:22 PM   #268
RocketKing
RocketKing's Avatar
Thanks!
Ya know once the gears start turnin' on an idea its hard to get out of you head! An LS1 sure would look nice under that hood...
Rex
Old 10-21-2011, 02:18 PM   #269
Thanks!
Well after some research Im not sure what it is. LS for sure. 5.3 out of a 99 Silverado. But when it comes to the LS engines Im completely dumbfounded.
Old 10-21-2011, 03:34 PM   #270
RocketKing
RocketKing's Avatar
So was I, but this is the best place to find the info for them.
Rex
Old 10-22-2011, 10:16 AM   #271
RocketKing
RocketKing's Avatar
I was looking some different ways to run the wires into the cab, here I took a clutch linkage boot and turned it backward and cut out the end. Then I ran the wires in and put the engine cover on to see how it looks. I would still have to cover the wires with wire loom but wanted some opinions on if you guys think it is still too visible.
Rex
Old 10-22-2011, 10:18 AM   #272
67cheby
67cheby
67cheby's Avatar
looks great !!
67cheby is offline   Reply With Quote
Old 10-22-2011, 10:38 AM   #273
71Sleeper
71Sleeper's Avatar
Are you kidding me! That is a great idea and looks good too.
71Sleeper is offline   Reply With Quote
Old 10-22-2011, 11:04 AM   #274
Looks awesome. Im gonna have to steal that idea!
Old 10-22-2011, 11:14 AM   #275
raull
raull's Avatar
that's great , cant hardly see in and keep in mind once you install steering shaft and brake master it'll block the view some more , like it !!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
