Old 10-03-2011, 09:44 AM   #1
chevyrestoguy
chevyrestoguy's Avatar
Pinion Angle
I'm about ready to swap the old 3/4 rear end out of my '64 C-20 and replace it with a 12-bolt out of a '79 Suburban. I am planning on also installing 4" drop springs while I've got it apart. Because I'll have to weld in new perches to the 12-bolt, I have a question:
On coil spring set-ups with lowering coils, what is a good pinion angle for a street-driven truck that'll carry a load every once in awhile? I've done this before on leaf-spring cars, and it usually winds up about 2 degrees down, but I'm not sure if this same theory applies to a coil spring/ trailing arm suspension.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-03-2011, 08:58 PM   #2
ItsRandy
ItsRandy's Avatar
Re: Pinion Angle
Coil springs with trailing arms are different than leaf springs...no spring wrap-up with trailing arms. Go to this web-site: http://www2.dana.com/pdf/J3311-1-DSSP.pdf it has lots of really good information and you can download and print it for reference.
ItsRandy is offline   Reply With Quote
