Old 10-03-2011, 08:53 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Water disappearing - need some help !
WARNING - THIS IS KINDA' LONG, BUT I WANT TO BE THOROUGH.
O.K. - I need some help before I lose what's left of my mind. In the last few weeks, my 350/350 '70 C-10 Stepper has started "drinking" water. I say "drinking" because I am having to add 1/2 - 1 gallon of water to my radiator daily. I and several car-buds have looked all over and we can't find any obvious leak. Nothing dripping anywhere. New 16# cap holds pressure on 1-ton big radiator. No problem overheating (except in a slow drive-thru on a hot southern day w / A/C on. ) LOL!
Now, I would think "blown head gasket". O.K. No water in the oil, no oil or exhaust in the water. No water in the tranny.
NO RUNS, NO DRIPS, NO ERRORS !
I have put nearly 5000 miles on this truck with no significant problems. Still runs fine with no high speed miss. Buddy followed me for several miles & no sign of white smoke out exhaust.
This is what I get for spending too much money on her.
DETAILS:Basically stock 350/350 - PO likely 25-30K miles??
Only other thought I've had is a hairline crack in a cylinder head between the water jacket and the exhaust port. "Sucking water out at speed???" I really don't want to tear into a good running engine, but this has got to stop.
O.K. gang, Help me solve this puzzle. It's my Daily Driver.
TobyArnot is offline   Reply With Quote
Old 10-03-2011, 09:03 PM   #2
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Water disappearing - need some help !
If you don't have an expansion tank, maybe coolant is expelled as it heats up and expands. Are you filling the radiator to the top when its cold?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 10-03-2011, 10:09 PM   #3
Lee H
Lee H's Avatar
With no expansion tank, stock set up, water level should be about 3 inches below the top. Anything above goes out the overflow as your driving.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-03-2011, 10:12 PM   #4
71swb4x4
71swb4x4's Avatar
I agree with the others. Either add an expansion tank, or leave it 1/2 gallon low and keep checking it. If it still loses 1/2 gallon every time you have a problem. I suspect it's as the others above say, you are loosing it when it expands, and that probably always happens while you are driving so you don't notice any dripping.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-03-2011, 10:31 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Have you tried pressure testing the system? Check for leaks with engine off & preferably cool, so small drips won't evaporate before you see them.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-04-2011, 07:19 AM   #6
TobyArnot
TobyArnot's Avatar
Allright gang,.
I do have an expansion tank plumbed from radiator overflow to bottom of a JEG'S plastic bottle. Doesn't seem to ever have anything in it. (vented top-open).
Sytem was pressure checked and held 16-13# for at least 5 minutes after shutdown during heat-rise period. No carbon mo. in water...New STANT cap 16# (too much?)
Now, maybe you guys understand my frustration. I've been around SBC s all my life and can't remember this ever happening before.
That being said, am I chasing a problem that doesn't exist. Is 3"-4" below the cap normal? I noticed that the highest point of the top hose is higher than the fill tube. Is that normal? I have tried filling it cold, filling it idling with the thermostat open, running with the cap loose, about every senario I can think of. Same result. Drive 25-30 mins. on freeway and - BINGO - water low. I'm going to resist the urge to check it for a day or two. Maybe that's "THE NEW NORM.".
Anyway, thanks for all the expertise. I will keep you all updateD as it goes.
Old 10-04-2011, 07:43 AM   #7
cdowns
cdowns's Avatar
expansion tank recovery system is dependant on having the proper type of radiator cap
i'd check real good the waterpump weephole
Old 10-04-2011, 09:11 AM   #8
71swb4x4
71swb4x4's Avatar
I think 3" is normal.
Old 10-04-2011, 09:54 AM   #9
kieth
kieth's Avatar
I had a customer with a Freightliner Tractor, it was losing about the same amount of water everyday, we thought it was going to be overhaul time (7-$12,000.00 until he pulled up one day and we popped the hood open and saw a very fine mist coming from one of his heater hoses, it was just a mist and it evaporated instantly....mystery solved......just replaced the heater hose.......we had been trying to find it for a month. sometimes it is something simple. Kieth
kieth is offline   Reply With Quote
Old 10-04-2011, 10:00 AM   #10
Vintage Windmills
Vintage 4x4s
I'd let it idle with AC on while on some pavement and inspect for leaks while it warms up and gets hot.
Old 10-04-2011, 10:21 AM   #11
fatboys69
fatboys69's Avatar
Had kinda the same problem, was loosing water n could not figure out where it was going. changed everything, water pump , heads , gaskets , hoses , had radiator cleaned and check all to no avail. AFTER buying a rebuilt engine and pulling the old one out I found the problem, a leaking freeze plug BEHIND the motor mount. May wanna check them as well. JMO
fatboys69 is offline   Reply With Quote
Old 10-04-2011, 10:22 AM   #12
bmfm64
bmfm64's Avatar
Does it continue to get lower and lower or does it seek a level and land there?
bmfm64 is offline   Reply With Quote
Old 10-04-2011, 10:23 AM   #13
TobyArnot
TobyArnot's Avatar
Hey guys,
All good advice. I'm think I'm going to try the "idle 'til it leaks or blows" test.
At this point, I'll let here blow steam til the cause shows up !
Old 10-04-2011, 11:20 AM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Start with a radiator full of coolant, and your expansion tank 1/3 full of coolant.
Close enough -- 15# is OEM. With a sealed system (that is, with an expansion tank) you need a cap for a sealed system -- standard cap will not work.
- Mike -
RIP El Jay
Old 10-04-2011, 08:32 PM   #15
TobyArnot
TobyArnot's Avatar
UPDATE:
Filled the rad., ran @ idle for 20 min. w/AC on. Never got over 200*, nary a leak.
Shut off, let it cool down, stiill no drips. Open cap and -BINGO- down 3".
Screw it, I'm gonna drive it and see what blows first!
What is a "correct" part # for a cap. I have a new cap and it's supposed to be correct.
STILL AT IT !
Old 10-04-2011, 11:23 PM   #16
treveiger
treveiger's Avatar
Have you left it go an see if it gets lower then 3 inches
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 10-04-2011, 11:28 PM   #17
bmfm64
bmfm64's Avatar
My truck always runs a little low too, where is your overflow mounted? Is the lid higher than radiator cap?
Old 10-05-2011, 12:59 AM   #18
TobyArnot
TobyArnot's Avatar
I'm using a plastic catch can from JEG'S. see pic, mounted straight up, on right front inner fender, about level with the exhaust port. sorry no picture. It's late. Line runs from rad. overflow to bottom fitting. I pulled the top fitting and it's grommet out. Left about a 1/2" hole in top. This should work.
I'll keep digging !
Old 10-05-2011, 09:02 AM   #19
bmfm64
bmfm64's Avatar
So once it goes down 3 inches does it stay there or does it continue to lose water?
Old 10-05-2011, 09:31 AM   #20
chopnchaneled
chopnchaneled's Avatar
Would your 350 happen to be a vortech? Had an issue with mine using coolant and it turned out to be the intake gasket was leaking into the cylinders while running.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 10-05-2011, 10:03 AM   #21
Shyguy
Junior Member
Shyguy's Avatar
Yep, my brother had a '95 and '98 with the leak in the intake gasket. After he replaced the gaskets he had no further problem.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-05-2011, 11:02 AM   #22
TobyArnot
TobyArnot's Avatar
That would be the current test. Filled it last nite, drove about 20 mins. last night. Drove it 20 mi. to work this a.m. on freeway. I'm going to resist the urge to top it off. Gonna' drive some more later and see where we are.
Not a Vortec -strickly old-tec.
AGAIN ; Thanks to all of you for your thoughts and input
Old 10-05-2011, 11:33 AM   #23
Crabass
I'm inclined to agree with Chopn and Shy, I think there's a good chance that coolant is being pulled into one or more cylinders. Had the same thing happen to a 4.3 with about 150K miles. It finally got bad enough so that I began to notice that when started cold the exhaust seemed to "steam" a little more than usual, or than other vehicles that were started at the same time (depending on ambient temp and humidity). Finally figured it out when I started it cold with the radiator cap off------blew coolant out of the open radiator a foot or so. Turned out that the steel shim factory head gaskets had deteriorated enough to let intake vacuum suck coolant into a couple of cylinders. Yes, even though I had always maintained clean and correct antifreeze/water mixture.
I agree also that intake gaskets are a very likely suspect. You might consider pulling the spark plugs to see if there is any unusual discoloration. I'd think if there was some, but evenly so on most or all plugs, that might be more likely intake gasket related; if just a couple or few are more heavily discolored, more likely head gasket or something cracked. And if I'm making no sense, just disregard me completely, I won't be offended.
Crabass is offline   Reply With Quote
Old 10-05-2011, 11:59 AM   #24
domeier
domeier's Avatar
That's about where mine runs. I don't have an expansion tank, so it just blows out the excess until it hits about 3" down, and stabilizes there. Is your expansion tank working? Does the level go up and down?
domeier is offline   Reply With Quote
Old 10-05-2011, 12:04 PM   #25
domeier
domeier's Avatar
Hey, I just remembered something: When I bought my truck, I found that some friggin moron PO had sealed the bottom of the front right fender with silicon. That just happens to be where the coolant overflow tube dumps. There must have been a gallon of coolant drained out of there when I cut out the sealant. I guess that doesn't apply to your particular problem, but something for people to look out for anyway.
