09-30-2011, 05:29 PM | #251 |
VA72C10
Re: Project: "Home Grown"
welded would look cleaner...you could plug weld the bolt holes then weld the edge and grind smooth...
Looking for a 67-72 swb or blazer project in or around VA. |
09-30-2011, 07:37 PM | #252 |
The lowers are a pain to press out with that tapered ball joint cup.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
10-03-2011, 08:26 AM | #253 |
10-03-2011, 11:51 AM | #254 |
I wouldn't heat the arms... might have to make a tapered block to use?
10-03-2011, 12:23 PM | #255 |
I think we may try an air hammer on it, will likely destroy the ball joint but oh well.
10-03-2011, 05:13 PM | #256 |
Does anyone know how to tear down these damn arms? I want to get them powder coated a different color but I cant seem to see how to get the shaft out of the arm? I am thinking it was likely pressed in originally?
10-03-2011, 06:11 PM | #257 |
Eat, Sleep, Drive a Chevy
Nope, the shafts are threaded on both ends. put the shaft in a big vise and unscrew the ends
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
10-03-2011, 06:14 PM | #258 |
We disassembled a set about a year and a half ago to make delrin bushings for them so they would be compatible with the Dropmember... the bushings are in there pretty tight. They will eventually come out with a lot of effort and even more patience.
10-03-2011, 08:48 PM | #259 | |
Posted via Mobile Device |
10-04-2011, 09:32 AM | #260 |
Looking at the break down photos of these arms it would seem that all I need to do is press them out one end, remove the bushing and repeat, maybe I should grease them up to get them to slide easier? I wonder if a little heat would help out as well?
10-04-2011, 09:34 AM | #261 |
What was a good deal is now turning in to a PITA!
10-04-2011, 10:00 AM | #262 |
67cheby
i would try to cool them rather than heat them, stick them in the freezer for a couple of hours and try it ?? it wont cost anything to try maybe it will work maybe not?
10-04-2011, 10:39 AM | #263 |
Hmm, that is a good idea, maybe it will make the poly a little more rigid and will stop it from gripping on the metal. I have a freezer here at work
10-04-2011, 10:46 AM | #264 |
Or I just leave the damn things black, the cross member will be a charcoal, and so will the spindles, the arms could be black along with the frame. So it will kinda flow decent. Any thoughts?
I just don't want to destroy these arms to only for powder, plus I would save a few bucks not needing to powder them |
10-04-2011, 10:50 AM | #265 |
67cheby
i think that would look fine !!
10-04-2011, 10:55 AM | #266 |
Lookie what I found today!
http://cgi.ebay.com/ebaymotors/GM-12...#ht_500wt_1182 Wonder what it will go for |
10-04-2011, 10:57 AM | #267 |
Anyone know enough about rear ends, would this work in my rear end, mine is a 70 12 bolt.
http://cgi.ebay.com/ebaymotors/12-Bo...#ht_500wt_1182 |
10-04-2011, 10:58 AM | #268 |
Me too.. (leave them black) Sorry to hear that the arms are a PITA.. I didn't realize that they were so difficult to tear down.
10-04-2011, 10:59 AM | #269 |
Not your fault man! I bet I can still get em apart, just don't want to make it a nightmare, besides once inner fenders are installed, who will really notice the arms anyways?
10-04-2011, 11:01 AM | #270 |
10-04-2011, 11:05 AM | #271 |
We didn't care about the bushings or the shafts in our case, as they weren't going to be re-used in our application. It was a bit of work. One of the bushings didn't survive. And we ended up cutting the cross-shaft in pieces on the second arm to save time.
I would recommend to leave them as is, rather than risk damaging something that they aren't "currently" building anymore. Black will flow just fine with the chassis.
10-04-2011, 11:07 AM | #272 | |
10-04-2011, 11:12 AM | #273 | |
10-04-2011, 11:22 AM | #274 |
Xmas from UPS today ! CPP Tubular motor mount perches.
10-04-2011, 12:21 PM | #275 |
Restoration Virgin!
TRW is made by Moog as well....check Rockauto.com for deals....there's a 5% discount code available...just google for it
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
