I removed my gas tank today (pics) have a few questions..
I removed my gas tank check it out. My buddy says that the caked on dirt isnt dirt but a kind of protectant gm sprays on the gas tanks. I think my buddy is a idiot and think its just caked on dirt. When I scrape the caked on dirt with a screwdriver it comes off easily. My truck is a 74 swb.
Re: I removed my gas tank today (pics) have a few questions..
Heres the inside of the tank has some minor rust in the bottom. I sanded it with some fine sandpaper and it came off pretty well (after pic was taken). I still dont know if I should clean this one up or buy a new one. The bottom just has this light rust the rest of it is in very good shape.
Is this how the cover should be or is it cut? I have no clue.
My fuel gauge is stuck at 1/4 and doesnt move. Im going to but a new floater. Heres the old one. Notice the frayed wire, may that be the cause? Im also going to get new fuel lines the old ones like like crap.
Poor or no ground is typical with fuel gauges, looks like you found your problem.
It's up to you if you want a new tank. Etch this one, apply a coating and re-use it if that's the worst of it. Yes your friend is an idiot. Pressure wash, etch and paint the outside. I recommend engine enamel, it will always stay clean and won't rust, ever. Same for the shield. |
![]() Join Date: Jul 2010
you can use a gas tank sealer kit to coat tha inside of tha tank..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
x2. That's like someone telling me the caked on oil and dirt on JUST the front of my rear axle is the same coating.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
Just here to tinker
![]() Join Date: Jun 2008
Yep. That's how they look.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
That tank is CLEAN on the inside. I've run much worse. "I think my buddy is a idiot" HAHAHAHA.
Looks good to me inside and out. Any pointers for helping the process of loosening the bolts and straps?
#12 | |
