Old 10-06-2011, 10:42 PM   #126
doubleb's69
doubleb's69's Avatar
Re: 1972 Longhorn 4x4 Diesel Project
Hey Ryan I just found your thread. The longhorn is looking awesome. I knew you could fabricate but I didn't know you could do body work too! I was thinking about maybe starting a local 67-72 Chevy/GMC truck club. What do ya think. Keep up the great work and hope to see it at Good Guys next year.
Bud
doubleb's69 is offline   Reply With Quote
Old 10-07-2011, 03:05 AM   #127
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I won't make claims to being a body man. A club would be cool. If you're interested, a fellow member Lockdoc, Leon, is hosting a gtg at his place in Montezuma next Saturday. Go check out the Iowa section for details. They are always a good time!
Ryan
1969 Chevy milk truck
Old 10-07-2011, 05:46 PM   #128
doubleb's69
Sounds cool. I think Fulmer is on board for a club too. I won't be able to make it to the get together but I do have family that farms out in Monti and it would kill two birds with one stone.
Bud
Old 10-12-2011, 02:50 PM   #129
Beat68CST
Beat68CST's Avatar
Hey Ryan, I started my 2wd swap, notched the top sides of the frame rails so the PS pump and AC compressor have a bit more room.
Doing a 95 P-pump with the 47RH behind it.
On your setup did you notice any flex in the frame?
Right now I'm cutting the main crossmember, the 84 disc brake one that I swapped in to lower it's overall height to get the crank centerline lower and some better oilpan clearence.
Beat68CST is offline   Reply With Quote
Old 10-12-2011, 09:00 PM   #130
Dieselwrencher
I didn't notice any frame flex on mine. How ever, my frame is the same as a 1 ton's frame.
Ryan
Old 10-12-2011, 11:19 PM   #131
mcbassin
Still Learning
mcbassin's Avatar
Nice progress Ryan! Sounds like you have a plan to get the truck back on the road. I like the way you make it sound so easy....I would have to spend several months on a small block swap let alone a diesel swap.
What kind of cherry picker/hoist is that so I know not to buy that one? I have actually been considering the elcheapo harbor freight mid grade model.
Old 10-13-2011, 12:54 AM   #132
Dieselwrencher
Mike, thanks for the kind words. It was through like an Ace tool or some thing but I think it is a China POS! I was set on getting a HF hoist when they were on sale for $99 and should have. I'm sure this one cost me triple that and it's worthless to me. Not what I ordered from him for sure. On the swap, believe me this one is way better than the 2004 F-250 I'm working on now. I have to get this truck done and that's why there's no progress on the poor Longhorn. There's always something. Hopefully this weekend I can get the rings gapped for the new to this truck engine and get the engine back together. With the turbos I'm planning on running, this should be a sure set up for 700hp. I'll have to get smaller injectors than what I had in the car other wise it's going to be smoky.
Ryan
Old 01-31-2014, 10:09 AM   #133
1972larry
Awesome build thanks for great pictures . Im looking to convert my 72 3/4 ton and you just helped me with all your details
1972larry is offline   Reply With Quote
Old 01-31-2014, 10:05 PM   #134
Dieselwrencher
If you have any questions feel free to ask. I'm slow to reply sometimes but I will. :lol; And pretty soon, I'll be starting a thread on another Longhorn 4x4 I'm going to be building for another member on here.
Ryan
Old 02-01-2014, 04:21 AM   #135
1972larry
What year of truck did you use front springs from? Or does it even matter im came across a cut of from 72 4x4 that has the correct brackets I need I figure its a start
Old 02-02-2014, 01:21 AM   #136
Dieselwrencher
If you have the front frame section from a 72 then you can use those. I used 73-87 springs because they are a little longer and provide a little smoother ride and are easier to get it seems.
Ryan
Old 02-02-2014, 10:43 PM   #137
1972larry
Thanks for info man
Old 03-02-2014, 09:51 AM   #138
hgs_notes
GEARHEAD
hgs_notes's Avatar
It's been a month. Been doing anything?
Here's some motivation...
http://www.enginelabs.com/news/a-die...427ci-duramax/
hgs_notes is offline   Reply With Quote
Old 03-02-2014, 01:11 PM   #139
Dieselwrencher
That is pretty cool, but break out the c notes, you're going to need a lot of them.
I don't have any picture worthy progress but I've been buying parts. My goal is to get this truck road worthy by May. I bought new 33 12.50 16.5 BFG AT KO's for it, ordered the billet input, an aluminum dinner double deep trans pan, a huge Hayden trans cooler, a trans pressure cable from lokar, and picked up a column shift tilt for it. I'm going to move my batteries and install my oil filter relocate kit, change my air intake pipe, and ditch the stack. I'm going to run exhaust outside the frame under the bed and have it exit behind the rear tires. I'm also thinking about buying a new wire harness for it and maybe a gauge change.
The build thread for this truck is now in the diesel conversion area of this forum.
Ryan
