Old 10-08-2011, 08:55 AM   #1
FL71C10
Opinion on repop doors
I am considering buying some new Tri-Plus doors locally. What do you guys think of them? I know there are horror stories of them not fitting well, but I also hear that Tri-Plus are better than most.
Any thoughts?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-08-2011, 11:40 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Opinion on repop doors
I got an older repop Suburban door that was just junk, I wouldnt have passed it off to anyone like was done to me.....I hope that the fit and metal quality has gotten better but you wont know until you open the package....
I would look for original doors....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-08-2011, 11:45 AM   #3
FL71C10
Wow. Maybe I should just fix what I have.
Old 10-08-2011, 11:46 AM   #4
partsman3
I bought 2 repop's from Classic ind. Dumbest thing I ever did. They don't fit right in any way. You'll see em on the parts board one day. Yes they'll be described that way.
partsman3 is offline   Reply With Quote
Old 10-08-2011, 02:08 PM   #5
leddzepp
Moderator
leddzepp's Avatar
A door has a lot of contours to it, making it very hard to reproduce accurately. I have NEVER heard a good thing about repop doors. I would try and locate a nice set of used originals.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-08-2011, 04:27 PM   #6
FL71C10
Or just fix mine.
Old 10-08-2011, 04:29 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by FL71C10 View Post
Or just fix mine.
yup...or just fix yours.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-08-2011, 04:32 PM   #8
72lb4x4
I almost couldn't give away a set of not very bad doors about a year ago. Needless to say I was pretty thin when I was in sales.
I got a set of 71 doors from the local pick-n-pull that are rust free. One has a big dent and the other a bullet hole, but otherwise they're great.
Used doors are out there, just troll the scrap yards and CL...
72lb4x4 is offline   Reply With Quote
Old 10-08-2011, 06:28 PM   #9
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I used a Tri-plus door a it fit just fine. The factory doors have something like under oat sprayed inside so they are heavier and close better. If you get some repros, spray some on the inside and you'll be ok.
Zoomin is offline   Reply With Quote
Old 10-08-2011, 07:19 PM   #10
jeremy zander
jeremy zander's Avatar
I tried to use some repops..they were not a good fit..they now hang out in the shed....
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 10-08-2011, 08:30 PM   #11
c50rob
I know nothing about Tri Plus, but recently purchased doors from Atheys that were KeyParts and the fit was perfect, truck is in paint shop now and I myself would never deal with trying to repair old doors again. Maybe the two I have are the exception to the rule.
c50rob is offline   Reply With Quote
Old 10-08-2011, 09:07 PM   #12
crazy longhorn
Fabricate till you "puke"
I would leave the bullet hole....just think about all the storys you could tell about that crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-08-2011, 09:54 PM   #13
El Campo
El Campo's Avatar
I have Goodmark doors and they do not fit worth a darn. Course I guess it is possible that it was my bodywork on the cab but I dont think so.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 10-09-2011, 10:46 AM   #14
biggestjohn
Got mine from Classic Ind. I had to cut (and reweld) the top of the outer window frame where the point is (front post and surround joint ) to provide the propper clearance around door opening, plus the body lines were out of alignment.
The door skin flexes like crazy ( oil cans, I think is the propper term ) It makes it very difficult to block sand because the surface is constantly moving. I had to re-enforce the inner surface to stop the flexing.
The door skin is NOT spot welded to the inner door shell, so I had to provide them so that I could then pull the outer skin into alignment with the cabs lines
(hard to explain)
In other words a major P.I.T.A.
biggestjohn is offline   Reply With Quote
Old 10-09-2011, 03:35 PM   #15
1972K20
1972K20's Avatar
Anybody used TABCO?
1972K20 is offline   Reply With Quote
Old 10-09-2011, 03:52 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Keyparts and triplus were the same. I just talked to Tim Christian about doors and he said Keyparts had worked on them and they are really good now. Keep in mind that every truck can be slightly different. I've used original doors that didn't fit one cab as good as another....
Old 10-09-2011, 03:56 PM   #17
Tim Christian
Tim Christian's Avatar
You must buy the doors labeled Key Parts not Tri-Plus they way more than the Tri-Plus and fit 100 times better!
Tim Christian is offline   Reply With Quote
Old 10-09-2011, 04:32 PM   #18
FL71C10
(hard to explain)
Wow, that's a lot of work!
Old 10-09-2011, 09:54 PM   #19
speedfreak369
speedfreak369's Avatar
where do you get the tri-plus doors?
1965 c10 short stepside (dad's project)
1967 c10 fleetside 350/350 trans (my baby)
speedfreak369 is offline   Reply With Quote
Old 10-09-2011, 10:41 PM   #20
biggestjohn
Yea, poor fitting aftermarket panels are why its taking me so long. I tried to fix the factory doors, but had the same problems with the door skins flexing, plus somebody didn't think to mount the doors on the cab before he welded in the door bottoms. (ain't mentioning no names)
Old 10-09-2011, 11:09 PM   #21
PHAT TONY
PHAT TONY's Avatar
I don't know about tri-plus, everyone else SUCKS!!!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 10-09-2011, 11:25 PM   #22
biggestjohn
I would be shocked if there was actually more than one factory reproducing these. It probably has more to do with the person assembling the pieces togather.
Old 10-10-2011, 12:38 AM   #23
AusTx68
AusTx68's Avatar
Another bad experience here. I bought two new repops. One didn't even fit in the hole. After a week of trying to make them work they got tossed and replaced with originals that needed work. They fit like a glove.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 10-10-2011, 11:11 AM   #24
Tim Christian
They are actually three companys that make these doors. Yes three set of tooling out in the aftermarket world.
Old 10-10-2011, 01:53 PM   #25
stich626
lol says the guy in texas..
try finding them up here that are not rotted all the way up to the upper hinge
stich626 is offline   Reply With Quote
