Front Fender Breaces
Are the fender braces on the front fenders necessary?
Posted via Mobile Device |
Re: Front Fender Breaces
I think they at minimum keep the fenders more rigid keeping them from sagging and flopping aound. And doubt Chevy would have gone through the expense of using them if they weren't needed. Do you not have them or are they in the way?
They're in the way and don't allow my truck to go down all the way when u release the air from the bags
I had to repair some fatigue cracks on my fenders so figured that there was a good bit of movement that they were restricting over the years. But then these were work trucks and most did not have an easy life. Try it without them and if you've got movement may be able to find another way to brace them.
How close are the running boards to hitting the ground now at full drop? |
The front running board brackets are on the ground and the rears are about an inch
I didnt have them on mine for the last several months mainly because I couldnt find them lol but I just found them and stuck them on.
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, |
Hey Texas, do the braces not rest on top of you tires?
![]() Join Date: Mar 2007
Im not running any. I noticed some slight movement (shaking) of the front fenders down by the bumper. I plan to make some bracing under the front of the fenders to tie iunto the frame in order to stablize the fenders better. I too am on bags with 20"s and decent size tires, so I would not be able to use them either......
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
