#76 |
made in america
Re: Project Goldilocks, '66 C10 SWB BBW Build
please take at least one picture of it laid out with those mudders on the back!
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree ![]() 2004 corvette- lowered, borla, tuned. slow ![]() my old girl 1966 c10- 305v8, t-5 sold |
#77 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Another great build from you keep it up..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#78 | |
Thanks dude! The bags and brackets from Jason at AVS came today. Going to get the brackets powdercoated before I install them. I'll take the C notches back off to get them powdercoated and I'm going to pick up the bed wear strips from a local shop tomorrow as well so I can get everything coated at once. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:30 PM. Reason: Fix dead pic links |
#79 |
Got the four short boards cut to length and the edges trimmed, then feather-edged the seam where I had to glue the filler strip in. Skim coated the edges and sanded them smooth so they're ready for primer.
![]() ![]() Also got some paint mixed up for the engine. I found a spot of original paint on one of the valve cover hold downs and took it to a local paint shop to get it matched. It's a little brighter than what's on the hold down so I may add a little black paint to darken it some. ![]() I've been researching hop-up parts for the 250 and it seems like Brazil is the place to go if you want a hot six. I'm thinking about a set of triple two barrel webers for it, billet rods and pistons, cylinder head work, 13:1-ish CR and a big cam on E85, a tuned header, and get everything balanced. I can't find anybody that makes the intakes to mount the weber carbs though. Crower makes a few different cams and billet steel rods for it, and pistons wouldn't be hard to find. This guy is running a 250 in his Chevy Opala and it runs mid 11's in the 1/4 mile.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:31 PM. Reason: Fix dead pic links |
#80 | |
Opportunity usually comes disguised....As hard work!!! ![]() |
#81 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#82 |
Rollin' Old Skool
nice work, & i'm tuning in for continued progress! good to see a fellow 60-66'er who is relatively in my neck of the woods, doing quality work
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#83 | |
Thanks! Charleston isn't too far away! Made a little progress today. Got the front springs out and the front bag brackets and C notches blasted and painted. I had some parts to blast at work today anyways and I already had the paint so I decided to go ahead and paint them instead of waiting for powdercoat. This way I'll be able to install them sooner. I ground the welds down on the C notch before painting. ![]() ![]() ![]() ![]() The paint is still wet in this shot so it looks glossy but it'll dry out to a low gloss finish and match the frame pretty well. ![]() Springs out, sitting on the bump stops. Didn't realize it would sit that low! ![]() ![]() Also pulled the manifolds off the 250 and this was what was inside the intake ports. Not what I wanted to find. Hopefully the block can be salvaged. ![]() More soon. I called and ordered the bed wear strips today and they'll be ready to pick up on monday. I'll test fit the wood floor once I get them so I can mark the fenderwell openings and perimeter holes for cutting/drilling. Then I can get the wood painted and get the bed back on the frame. I'll get the cross channels and the wear strips powdercoated before the bed goes back on the frame, and also clean and undercoat the inside of the bedsides with Duplicolor truck bed liner like I used on the blue '65. Hopefully the powdercoater doesn't take too long and I can have the bed back on in a couple weeks.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:33 PM. Reason: Fix dead pic links |
#84 |
Rollin' Old Skool
true dat, haha...maybe one day when my truck makes its way to SC, we can meet up....
those notches look great smoothed up & painted...hope the engine works out for ya
#85 |
Great project, love the 6 plan. That Opala completely rocks, hope you get your six to that level, I'll definitely watch with interest.
#86 | ||
Got a little bit done this afternoon, worked in the yard most of the day. Flipped the frame up on its side so I could drill the bottom holes for the C notches and bag mounts. Man I hate drilling holes in steel this thick! ![]() Here's a mini tech tip. Put some wide tape over the part that you will be mounting (bags in my case), and mark where the holes are. Then transfer the tape and use the markings as a template to drill your holes. You can center punch the part while the tape is on there too, and I was able to peel the tape off and use it again for the other side. ![]() Center punched: ![]() And here's what the notches looked like once the paint dried, its a fairly close match to the frame. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:34 PM. Reason: Fix dead pic links |
#87 |
![]() Join Date: Mar 2005
Very, very nice work! I really like your attention to detail. All of that extra work will really pay off in the finished product.
Your tape template trick works well, as I have used it before. Another trick that works is to use a scrap piece of sheetmetal and double-back tape it or loop some duct tape to keep it in position. I work in aerospace, and when we transfer holes, we use a drill bushing that has an O.D. that fits in the hole in the part (in your case, a 1/4" or .250"). The I.D. of the bushing has a small hole, usually around a .080". When you pop the holes, it's dead center in the middle, and then you remove the part and the bushing, and then step-drill to the final size. You can find drill bushings on-line in places like ebay. A lot of times, guys fight drilling holes in steel because they try to drill the final hole size at the start. Always step drill, and work slowly. It'll save your drill bits from wearing out, and it'll keep you from breaking your fingers when the drill catches at the end. Been there, done that, but usually with a drill press. Those things can be evil
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#88 |
Great tips guys. Thanks for instructing us.
#89 | |
I'd never heard of drill bushings before, I'll have to look those up. Good to know! I did start out with a 3/16th hole before working up to a 3/8" bit for the air bag mounts, then 1/2" for the air line fitting, then using the air grinder and a carbide burr to open the hole up the rest of the way. I should have used a hole saw for the air line fitting; I'll know better when I do the other side though. I went slowly and used alot of pressure on the bit and kept it cool by spraying it with glass cleaner every few seconds. The bits aren't discolored or dull yet so I guess my method is working ok. I use the looped tape trick all the time to keep masking paper/plastic in place, remembered that one from hanging up pictures of trucks I'd drawn in kindergarten ![]()
#90 |
![]() Join Date: Sep 2009
clifford sells manifolds for mounting webbers to chey sixes. if you are serious about building a six you need to get Leo Santucci's book. those guy's in Brazil are getting 800 to 1100 horespower out of turboed 250 chevy sixes.
#91 |
Artist
![]() Join Date: Jan 2010
well Im doing a VERY similar build.... Stock "looking" but lowered. My Little V8 will "Look" like a stock 283/327.... MUHAHAHAH.
You do AMAZING work!! So on mine I ran CPP's shock relocators with CPP shocks... It rides AWESOME! Better than my 03 dropped half as much!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
#92 |
Rollin' Old Skool
thanks!
#93 | ||
Thanks dude! I'm waiting for updates on your build thread! I checked it out awhile back and love the style you're going for- that engine looks great! Good to know on the shock mounts, I'll look into those. I'm thinking about building my own, not sure yet but its good to see what others are running to get ideas Welcome! Got a little done last night. Went and picked up the bed wear strips from Trucks USA in Greenwood, SC (they look and fit great btw) and took the four short boards and two outer long boards home with me to mark the fenderwell openings and perimeter bolt holes. Only took a couple pics though. I should be able to get the bed wood painted this week, will have to wait til the support rails and wear strips are back from powdercoat before I can get the floor back in. Gunna scrub down the inside of the bed with steel wool and CLR while I've got the floor out to get rid of the rust stains on the tubs and flanges. I'll probably go over the paint inside the bed with some sort of cleaner wax to spiffy it up a lil bit too. ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:35 PM. Reason: Fix dead pic links |
#94 |
Progress may be slowed up a little on my '66. Dad found a '50 Chevy in a barn about two miles from the house and bought it yesterday so I'll be helping him get it back on the road. I'll start a build thread on it once we get that far with it. Plans include a dropped axle, bias ply tires, and leave the body like it is and run it. It's got a '59 engine that was running when he parked it (brakes went out) and hopefully won't take much to get it going again.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:36 PM. Reason: Fix dead pic links |
#95 |
PROJECT 7DEUCE
Nice find...
#96 |
Outstanding...have fun.
#97 |
I started cleaning up the lip around the fenderwell and bedsides last night. The lip is still the original paint, I guess the guy who painted the truck didn't want to mask out all the bolt heads so he just masked off the whole lip. I used 0000 steel wool and CLR to take the rust stains off which worked pretty good. I'll go over the whole thing with Johnson's carnuba paste wax to seal it up once I get the whole thing done. I'll have to resize the pics before I can post them, I'll edit them back in here.
Also got the backside of the wood floor painted last weekend. ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:37 PM. Reason: Fix dead pic links |
#98 |
Couldn't figure out how to edit the post to add pics (I've done it before?) so here they are.
![]() ![]() *Edit* I guess you have to edit a post within a certain amount of time or before logging out. It let me edit this one...
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:39 PM. Reason: to add that I figured out how to edit... doh! |
#99 |
nice project!!! subscribed
#100 |
Thanks!
I got the engine torn down last night. The cylinders had a touch of rust around the rings but nothing that won't clean up when its bored. The crank journals look pretty good and I can't catch any scratches/gouges with my fingernail. I used a set of numbered dies to mark the main bearing caps and the main webs in the block to keep track of their orientation before taking them off, definitly didn't want those getting mixed up. The lifter bores look really good and the lifters were nice and tight in the bore. I had been looking into putting a solid roller cam in it, but I've only found one company that will custom make them, and listed the price as "call for price". That usually means $$$$$ so I'll probably stick with solid flat lifters. Hoping for 375+ horsepower, does that seem doable with this combination of parts? Plans for it so far include: Bore the block enough to clean up the cylinders. Balanced stock crank. Lighten the flywheel. Eagle forged 4340 rods, 5.7" Forged pistons, haven't found any "off the shelf" yet. Head bolt boss removed from intake port, lump port kit installed. Larger valves, ported heads, decked for more compression. Block decked for .040-.050 quench. 13:1ish compression (will be running E85, 105 octane) Solid flat cam, wanting it to pull to around 7000-7200 rpm. Comp Cams Aluminum roller rockers, 1.75 ratio. ARP main and head stud kit. Triple Weber/Dellorto 2 barrel side draft carbs 6 into 1 header, single 3" exhaust, magnaflow/dynomax straight through muffler? ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-07-2012 at 02:39 PM. Reason: Fix dead pic links |
