Old 10-08-2011, 11:20 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Confused about Motor Mount options
I'm confused about the motor mount options for the LS1's. Which is probably a sign I shouldn't delve into this, but I've never obeyed those signs in the past so why start now.
I guess I'm confused about the $25 adapter plates compared to the $219 ECE kit. What's the difference and which one is more "cost effective"
The LS1 I'm picking up has the original A/C compressor still with it. I'm putting this in my burb and will have to go Vintage Air at some point. I know that's another question in it's self. I'm not trying to make this look good, just want it bolted soundly to the frame.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 10-09-2011, 09:47 AM   #2
pat565
Re: Confused about Motor Mount options
The adapter plate allows you to bolt up a standard sbc mount to the ls block. -This works for some to use the existing mounts to mount into the chassis. I have just done this in my 71.
The other kits gives you everything to get the engine mounted to the frame using nothing from your original setup.
pat565 is offline   Reply With Quote
Old 10-09-2011, 11:00 AM   #3
5150
C10 Club Tennessee
5150's Avatar
The only thing I have left is the original stands in my 72.
Bryan
www.gmtruckshow.com
Old 10-09-2011, 12:29 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
its hard to beat the cost of the adapter plates. There are a few different ones out there, with different offsets that can move the engine forward or back for clearance.
Even with newer mounts and hardware, the adapter plate setup cost me no more than $55. I didn't see a reason to spend another 150$ that could go elsewhere.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-09-2011, 02:54 PM   #5
pat565
I did modify mine to set the engine back. I had to cut the front hole that would hold the upper from sbc mount bolt, to gain cleance for the AC with the factory brackets ( on the 5.3). I then ended up fipping the mounts side to side and dilling and tapping one hole for the new location of the sbc mount.
In the end, the frame mounts are in the two rear holes on upper frame flange, and the trans crossmember is in the most forward set of holes. This should push the engine back to make it sit a bit tighter to the firewall.
Old 10-09-2011, 09:05 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
I used the cheaper style plates on my install with what I think are the 73 up style engine stands. I had to drill new holes for inboard mounting holes. I also moved the passenger side back to accommodate the a/c compressor. Which means I had to cut the angled portion that side adapter plate and then made a brace to use the last hole and carry the weight on the back. The reason I went with this style stand, I think they are a better design and I never liked the 72 back design (I had one break on me and the whole engine would raise up.
Here are the pictures I have, I will try to get more when I get back to my build.
Old 10-11-2011, 11:12 AM   #7
5150
C10 Club Tennessee
5150's Avatar
This is what I have now
Bryan
www.gmtruckshow.com
Old 10-11-2011, 11:22 AM   #8
mcbassin
Still Learning
mcbassin's Avatar
I had those same mounts too but I really don't care for the motor mounts on this style. (just my opinion though). My reasoning, I have a 402 in my 70. It used to eat those mounts for lunch. when they fail the whole engine raises up. Not cool The newer style can fail and the engine can't raise up more than the inner mount. Like I said, just my .02 cent.
You can pick up the later stands at pull-a- part cheap. Good luck.
Old 10-12-2011, 11:25 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^^ torque straps
Old 10-13-2011, 12:07 AM   #10
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by BR3W CITY View Post
^^ torque straps
Yep, back in the day we used chains too
Old 10-13-2011, 01:00 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
that sounds noisy.
I really want to get a set of torque/limiting straps for me engine once I've got the procharger setup done, but I will admit they don't look nearly as cool; as they would on something with a big bds sitting up top.
Old 10-15-2011, 08:40 PM   #12
pat565
Put an F3 and gear drive on then!
Old 10-16-2011, 02:57 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I can put an intercooled D1sc on it (or use meth) and change pretty much nothing but cam and tune. If I went that big it would be engine build time. Maybe someday.
Old 10-16-2011, 03:48 AM   #14
jays68yak
jays68yak's Avatar
In my experience...the towers you currently have on your frame are going to cause exhaust manifold/header clearance issues. If you run stock 72 towers and adapter plates, or 73 up towers and adapter plates, or the ece kit you would be good. I've done a 72 using the stock towers and adapter plates, along with the lsx swap headers. That was the best one imo. Also done a 71 and had to cut the tower up for clearance.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 10-16-2011, 10:00 AM   #15
pat565
The stock frame stands can fit nicely with the factory A/C on the LS using Doug Thorley headers. They were made for these trucks, so they look and fit awsome
