10-02-2011, 10:54 PM | #4026 |
Re: What did you do to your truck today?
I got a good start on removing stuff from my cab. Getting ready to lift it off the frame. I still have to remove the windshield, rear glass, and steering column still.
10-03-2011, 01:59 AM | #4027 |
Senior Enthusiast
Back around 1970 I picked up an original Yankee peep mirror in a wrecking yard. I subsequently used this exact mirror on my 1949 Plymouth, 1954 Chevy, 1946 Ford, and even on our 1960 GMC when first acquired. I always loved the looks of the mirror and the vision provided with the mirror so close to my head. Eventually it was replaced with stock door mirrors since the factory nutserts were already in the driver’s door.
Having used it for years, nostalgia got the better of me and I temporarily mounted it to see if I could go back, the intention being to get rid of both door mirrors if it worked well. So far I’m not impressed with the vision. I only drove it at night, but I couldn’t see anything but reflections in the window glass. I’ll try again tomorrow and see if getting use to it again makes any improvement. |
10-06-2011, 09:00 PM | #4028 |
I got my door glass all in on both doors, just in time because my seat just came back from the upholstery shop
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
10-06-2011, 10:11 PM | #4029 |
Senior Enthusiast
Nice job!
10-07-2011, 04:08 AM | #4030 |
Finished off putting in my air ride system, took me 3 days not too bad considering I,ve never put them on before. Doesn't drop it all that much but does it ride a whole lot better
10-07-2011, 04:23 AM | #4031 |
I finished stripping everything off of my cab. Got all the glass out without damage. Ready to deCABitate it from the frame as soon as I can round up son and his friends. Ah, nothing like young muscle to help the old man out. I'm sure it will cost me some beers but it's beer well drank.
10-07-2011, 09:01 AM | #4032 | |
10-07-2011, 11:53 AM | #4033 |
Sweet seat, Leadfoot!
10-07-2011, 02:19 PM | #4034 |
primered the outside of the cab - inside's painted, starting to look like someone's restoring it.
doors next. |
10-07-2011, 06:48 PM | #4035 |
put the passenger side mirror on--what a pita
10-08-2011, 08:35 PM | #4036 |
Spent a better part of the day lining up the front sheetmetal, trying to get all gaps close as possible and body lines somewhat strait, end result, doors and hood shut better and body looks straiter without ever touching bondo or sandpaper!
10-09-2011, 05:47 PM | #4037 |
Finished the teardown of the 250 and got it ready for the machine shop. But mostly I got an old boat trailer out of the woods to use as a Carrier for the cab and bed when I take them off for restoration.
10-09-2011, 07:38 PM | #4038 |
cut out some more brackets under the frame,installed the left side rear disc,made a hanger for the flowmasters and cut out the fear inner fenders.
big old burb in primer.lot of work to do. |
10-09-2011, 08:19 PM | #4039 |
One foot in front of the other
Almost done with grill
10-09-2011, 08:20 PM | #4040 |
I put a throttle return spring on to keep the revs in check, then I test fit my chrome GMC grille
10-09-2011, 08:31 PM | #4041 |
Put the truck to the side to day and spent some good time with the family.
10-09-2011, 08:41 PM | #4042 |
Good decision- very important.
10-09-2011, 09:22 PM | #4043 |
C30 sway bar for my c10 |
10-09-2011, 10:31 PM | #4044 |
Great score on the C 30 Sway Bar and it even came with Poly bushings - that's pretty hard to beat.
10-09-2011, 11:44 PM | #4045 |
finally have lights! didnt have the front or rear lights.traced it down to a bad ground so i know have front lights. gotta figure out the rear still. oh yeah installed a new headlightswitch and domelite too. not much i know .
Posted via Mobile Device |
10-09-2011, 11:45 PM | #4046 |
yeah... I got a nice tow hitch with the sway bar for 44 bucks and change.....
10-10-2011, 02:04 AM | #4047 |
Yes, I would say you definately scored BIG time!
10-11-2011, 03:03 PM | #4048 |
Over the past month I had to rebuild the top end of the "professionally" build SB 357 motor I installed in August of 2010. Had nothing but problems with this from the first week out. Did not want them touching it again so. I did all the work myself - for the first time.... Just found out that the shop that built my motor is out of business.....
Had to swap heads: now running GM 185 head w/t 2.02/1.60 valves, Edelbrock RPM 7102 cam and lifters: .488/.510 lift. Running Performer intake and carb for now. Motor still looks the same as last year but runs so much better! Also running 17" Brockman steel packed mufflers. Sounds damn good. Here's a lil vid of the exhaust note before the top end rebuild: Now maybe I can get on the front suspension. Rear was bagged this past June
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
10-11-2011, 04:01 PM | #4049 |
Didn't turn any wrenches but I did order the No Limit shock relocation kit and shocks. Time to get ready to work as soon as the new stuff arrives. I want the panhard bar from No Limit next.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
10-11-2011, 05:05 PM | #4050 | |
What did you pay and any contact info for them. Thanks!!!
