Old 10-10-2011, 12:20 AM   #1
shocker
Will 73-87 diffs fit?
Will 73-87 3/4 ton 4x4 diffs fit into a 1972 blazer without mods? What mods are required?
formerly cooter
shocker is offline   Reply With Quote
Old 10-10-2011, 09:19 AM   #2
turp mcspray
turp mcspray's Avatar
Re: Will 73-87 diffs fit?
Front will bolt in, rear will need spring perches and shock mounts moved.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-16-2011, 04:14 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
A 1 ton rear axle from the 80's models will bolt in as far as spring perch width goes (1 ton is narrower than a 3/4 ton). One thing to keep in mind when putting ANY 3/4 ton or 1 ton rear axle in your 1/2 ton is the axle tubes of the heavier axles will be of a larger diameter than your factory 12 bolt rear. This isn't the end of the world, but you will need to buy/build new spring plates and U bolts.
This is a great way to go.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 10-16-2011, 05:32 PM   #4
shocker
thanx for the help and info guys!
formerly cooter
Old 10-16-2011, 07:17 PM   #5
SILVER_WS6
I actually need to rebuild my 72 rear. Im not sure anymore what it is. I know its stock. Should just need wheel bearings and prob the carrier and pinion. Any ideas or numbers?
SILVER_WS6 is offline   Reply With Quote
