Old 10-10-2011, 10:32 PM   #1
68350
68350's Avatar
Brake Light/Blinker Issue
So my passenger brake light and blinker doesn't work. Taillights work just fine. I traced the harness all the way to the firewall, and there is no power for the passenger brake/blinker. Drivers side has power. The column has a purple wire and a double blue wire coming out of the connector, both of these have power when the passenger blinker is on. I cut the purple single wire and it cut power to the passenger blinker. So my question is, what are the double blue wires powering? I'm guessing one is for brakes maybe, and one is for blinker, but I don't wanna cut another wire unless I know. Can anyone shed some light on how to fix my blinker and brake light? thanks, Doug
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-10-2011, 10:37 PM   #2
bigbadchev72
People know me
bigbadchev72's Avatar
Re: Brake Light/Blinker Issue
It is more than likely a bad turn signal switch in the column
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 10-10-2011, 10:45 PM   #3
BMERDOC
BMERDOC's Avatar
I'd love to thank the guy who took time to do this but I don't know who did it. I'll thank him by passing it onto you. The files are big so you can save them and blow them up real big if needed.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-10-2011, 10:45 PM   #4
MacGyver72
MacGyver72's Avatar
I thought you had no power to the passenger blinker. As far as I know the larger filament in the bulb for both brakelights and turn signals draws power from the same wire. They probably merge at the firewall connection where you found the loss. It sounds like you have a connection plug issue to me. I'm assuming you've already ruled out a faulty ground. I don't know which cluster you're looking at on your column but perhaps one of the wires you refer to is in fact the brake wire and you should see it connecting to the switch at the pedal.
MacGyver72 is offline   Reply With Quote
Old 10-10-2011, 11:10 PM   #5
68350
68350's Avatar
Forgot to say this, the front passenger blinker works perfectly, so this is a rear passenger side problem only. It has power at the column half moon connector, and between there and the firewall connection, it loses power.
Old 10-10-2011, 11:14 PM   #6
MacGyver72
MacGyver72's Avatar
So it would seem that all you need to do is replace the wire from the column clip to the firewall. Try using a jumper wire from the battery to the firewall plug and see if you get the bright side of the bulb to light. If it doesn't, you have a firewall plug problem and then probably just a pin connection problem so no big deal. I would do that test before I cut any wires. No sense cutting what you don't have to.
Old 10-10-2011, 11:21 PM   #7
68350
68350's Avatar
ok that makes sense, I will try that and let you know how it works
Old 10-10-2011, 11:38 PM   #8
68350
68350's Avatar
rear harness is perfect. I connected the jumper from each of the four prongs to the battery, one lit up the right side, one lit up the left side, one lit up the taillights, and one lit up the reverse lights.
Old 10-10-2011, 11:41 PM   #9
MacGyver72
MacGyver72's Avatar
Cool! So it would seem that you now need to connect the jumper farther back until you have the loss of power. Usually a clip connection or a break in the wire cause this problem. If there are no visible breaks, you only have to clean up a connection somewhere and now you should at least know what color wire does what.
Old 10-10-2011, 11:42 PM   #10
MacGyver72
MacGyver72's Avatar
Could be the female end of the connector you just unplugged. You should see if the four prongs you tested fit tightly in the connector. Any loosness could explain your issue.
Old 10-10-2011, 11:45 PM   #11
68350
68350's Avatar
Shouldn't the plug in that comes from the interior through the firewall have power if checked with a test light? That does not have power on the passenger side rear.
Old 10-10-2011, 11:51 PM   #12
MacGyver72
MacGyver72's Avatar
Yes but you have to work backward to find where it's lost. The power should come from the fuse panel through a leg to the column. I suspect that if you already know that you have no power coming from the column that either the c shaped clip has a loose connection or the connection to the fuse panel is suspect. That is unless you find a broken or frayed wire.
I would keep using the jumper to check the connection just prior to the firewall (steering column?)
Old 10-10-2011, 11:53 PM   #13
68350
68350's Avatar
Ok, I will recheck the plug in at the firewall coming from the main harness. Maybe the plug in is bad, I could poke the wire to find out if they have power. I will check in tomorrow night and let everyone know what I find out. I checked the harness very well before installing it, so I hope its just the connector.
Old 10-10-2011, 11:54 PM   #14
MacGyver72
MacGyver72's Avatar
Good luck. You seem to be on the right track.
Old 10-11-2011, 11:44 PM   #15
68350
68350's Avatar
Well finally figured it out, it is the actual column wiring. Somewhere it is bad, I'm thinking where it is sotered/sautered(sp) into the plastic piece below the blinker piece. I did not have power at the half moon, I just had a dumb moment. So I will be replacing the wiring this weekend with one from a column I know worked. Thanks for everybodys help, I appreciate the wealth of info/help this board provides.
