09-04-2008, 05:53 PM | #1 |
Windy Corner of a Dirty Street
Heater core with A/C
Agh!
I had to open the ball valve to the heater core a few weeks ago when in the mountains as we needed heat and I noticed a few drips of coolant on the garage floor since I’ve been back. Finally got around to putting a pressure tester on it tonight only to find coolant leaking from the bottom of the heater core box. Checked the carpet under the Husky floor mat and...yep, it is wet too. I have never had to change a heater core in this body style truck. How bad of a mofo is this job going to be with A/C?
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
09-04-2008, 09:21 PM | #2 |
Re: Heater core with A/C
I used to think that all 5 or 6 of the bolts on the firewall had to be removed to do the job, which meant pulling the inner fender to get to the one below the blower motor, but that isn't the case. You'll see 3 studs with nuts on the outside of the firewall, remove the nuts and then you should be able to pull the whole plastic thing inside the cab out. That of course is after you take off heater hoses, unhook any duct work. Not sure if vaccume lines under the dash need to be removed or not.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
09-06-2008, 02:01 PM | #3 |
It's not too bad and like hrc200x described. I did pull the inner fender when I did mine several years ago and I found it made it easier for me. It's the lowermost bolt and nut that's the tricky one.
The great news is that the inside, underdash stuff is pretty straightforward. Just don't force anything and you'll be fine.
Semper Paratus |
10-11-2011, 04:39 PM | #4 | |
10-11-2011, 07:04 PM | #5 |
Scroll down on this thread and you will see some good pics on where the bolts are on the duct work, and info on replacing the heater core.
http://67-72chevytrucks.com/vboard/s...ight=defroster I don't see any need to remove the inner fender. I did mine without removing it and I have A/C. I recommend a good inspection mirror, flashlight, and flexible shaft for your ratchet so you can get to the bottom nuts on the firewall. Harbor Freight has a good set of flexible shafts for a few dollars. I also recommend a copper, not aluminum, heater core. |
10-11-2011, 08:45 PM | #6 |
I ripped out my inner well, but it was in need of replacement anyway so I just killed two birds with one stone. I had an issue getting the core out of the box once it was removed though, so I kinda had to force it out.
DEFINATELY go with anything but aluminum. Really, when I did mine, I should have just brazed the inlet pipe back onto the old brass core. That was why it leaked. Double whammy for me using the aluminum core is the fact that I have a diesel. You get heat in about 15 YEARS...
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
