Old 10-11-2011, 11:57 PM   #1
jdheff1982
Slop in front wheels
I am curious as to the best way to approach slop in my front tires. What I mean is that they have some wiggle room when the front is off the ground.
Would this be best rectified by replacing the bushings for the steering components or buying a whole new set?
Also, do any of you use a steering dampner? If so, is there any difference then w/o one? Thanks.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 10-12-2011, 12:03 AM   #2
BMERDOC
BMERDOC's Avatar
Re: Slop in front wheels
You have to determine where the "slop" is coming from. Loose wheel bearings, tie rods, idler, ball joints, etc...The entire front susension doesn't have to be rebuilt if one component has too much play. Make sure you take the tension off the lower control arm to properly test the ball joints and upper control arm bushings.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
