#101 |
67cheby
![]() Join Date: Sep 2008
Re: 1971 c10 stepside
SWEET ..i like em
#102 |
They look really good ..... I will come check them in person later.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#103 |
![]() ![]() Join Date: Jan 2011
285/35/22 on a stepper? I don't know man.. You leaving the stock fender wells, and/or mini tubs in the rear?
Hoping I'm wrong. Do you have the early rear end? 22x9 - 5"BS? What are the height / width specs on the rear tires? You're probably going to need to loose the support braces at least and/ or trim the fender lip a bit. Again, not meaning it negatively at all. I know a 265/40/22 - 5" BS with the early rear end requires trimming to fit. Assuming you're bagging the truck (?) Posted via Mobile Device
#104 |
thanks for the info i can use all the help i can as i've never done an old chevy truck , i know for a fact i will have to modify or even delete the brace for the drop , as far as the lip , we measured and got the right back spacing it's 5. so i'll post how it turns out when they are on
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#105 |
Ok, cool. Best of luck to you on the build! It's already looking awesome. Nice choice on the wheels too.
#106 |
thanks, not my first choice for wheels but the had the matte look i was looking for since i already have billet intros on my other ride, i wanted something different , as for the tire size i did some research and the 285 are 700 thousands wider than the 265 so that makes it a 350 thousands split between inner outter wall which its about 11/32 of an inch so if i have to trim it will be minimal , im hoping , thanks again
#107 |
VA72C10
![]() Join Date: Mar 2008
cool! love the way coys look on our trucks and the new finish will set it off!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#108 |
well i got the suspension on friday but work and family activities has kept me away from the truck , so this morning i snuck in the garage for 2 hours before wife and kids woke up and took apart the front end , cleaned and sprayed with some more bedliner spray and made the cuts for rear c notch , oh and yes 2 more fregging rivets showed up on me ,
#109 |
Great job brother!!!!!
#110 |
67cheby
Nice !!
#111 |
Nice. Engine and trans are out brother. Tomorrow I'll pull the harness and tank. She's moving right along.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#112 |
very good , thanks 4 d update
#113 |
hello boyz , its been none stop raining for the past 4 days here in south florida , but that wont stop me , found shelter to do some painting in a parts shed , and put toghether most of suspension but i ran into a few misshaps ,
also started to strip rear end for disc brake set up and a stubborn gear shaft woul not give , so i snaped a spring of the possie unit so thats when i called it quits as it was midnite already , here r some pix !!!!!!!!!!!!!
#114 |
pix
#115 |
67cheby
looks good !! like the silver contrast
#116 |
pix
#117 |
sorry for some reason today i can only uoload 1 pix at a time !!!!
#118 |
Great progress bro....you are flying thru this,,, I know that you are in heaven enjoying the built....
#119 |
VA72C10
Looking good!!!
#120 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Great progress.
I do have a concern. I think you have your upper a-arms on the wrong side. This appears to be the "passenger side" upper a-arm mounted on the "drivers side".
#121 |
WoW buddy , good job , late last nite i presented that side to take a picture and i notice it was stamp wrong , ( both sides ) so i swap them , gave ride tech a call today to let them know but i did not post it in here as i dont like to put nobody down , thanks for looking out though ,
#122 |
last nite i ran air lines to the rear and put back together the rear end gears so as for now im waiting on u bolts for front lower arms arriving tomorow as well as shock studs that were missing from the order and disc brakes kits that should arrive today , next task is to modify panhard bar bracket to work with the aluminum rear end cover
#123 |
pix
#124 |
![]() Join Date: Mar 2010
I might be the picture hiding it, but on the lower control arm. There should be a bracket to the front in the middle of the tube for the sway bar link. I didn't see it in the picture so I was just wanting to make sure.
Great progress by the way. |
#125 |
you are right, they sent some extra brackets in case i want to install in the future , they only welded the ones to the rear for the shocks ,
