10-13-2011, 04:39 PM | #1 |
Torsion bar bolt
Dumb question but never worked with torsion bars before. I want to lower my 62 and wanted to make sure If these were the right bolts to loosen? Thanks
10-13-2011, 04:48 PM | #2 |
Re: Torsion bar bolt
yes,those are the correct bolts,on mine the square upper nuts turn also so you will have to put a wrench on them so they don't turn otherwise it wont change your height.when i bring mine up close to stock height the upper square nuts don't turn but when the pressure starts to come off mine do turn.
good luck! |
10-13-2011, 04:59 PM | #3 |
make sure you count how many times you turn the bolts
10-13-2011, 05:17 PM | #4 | |
I rode the LOLO Motorway a couple of years ago on my 625 KTM dirt/street bike, it was really a neat ride. Hard to believe Lewis and Clark went over it in the 1800's....Really pretty country. Kieth |
10-13-2011, 05:37 PM | #5 |
they had to be some tough guys,they sure separated the men from the boys,in the last 30 years i (think)i have ridden every trail and old logging road around here it is beautiful country. thanks kieth!
10-13-2011, 08:42 PM | #6 |
Thanks guys, I'll post pics when I do it.
10-14-2011, 04:06 PM | #7 |
Is 4" to much to lower with torsion bars? How many inches is safe? Or how much did you guys lower the frontend? Thanks
10-14-2011, 05:35 PM | #8 |
I lowered mine 2 with the torsion bars and 2.5 with drop spindles. I don't know what is safe and what is not. But I have heard that if you undo them to much the heads of the bolts can scrape on the ground.
10-14-2011, 06:29 PM | #9 |
hey forestb, with the drop spindels how much did it drop. also with the drop spindels, did you have to run disc brakes?
10-14-2011, 09:36 PM | #10 |
2.5 inches and yes I did have to run disks.
10-15-2011, 12:52 AM | #11 | |
here is a picture of mine with stock suspenion and i think i still have 2" before it hits the snubers. |
10-15-2011, 10:04 AM | #12 |
Heres mine all stock. I dont think the PO lowered it at all. I just want to get rid of the gap up front and level it out.
10-15-2011, 04:23 PM | #13 |
Ok,you can easily lower yours as far as mine is with your stock suspension,but remember to lower each bolt the same amount of turns to keep it even.by the looks of yours i would take each one down about 4 turns,then roll the truck back and forth while turning the wheels.the truck will drop just a little bit more and you can get a accurate height.you will have to get the truck aligned after that because your camber should be off quite a bit but if you don't go lower than mine a front end shop will be able to set your camber with no problem.just be sure to use a front end man that that knows the older rigs.there is a big difference between a man that aligns a truck to specs and a good one who aligns it to the vehicle.
