Old 10-13-2011, 11:04 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
frontend help
well im ready to start tearing into the fronend stuff and i want to pull the fenders and grill of in one piece but how? were are all the bolts?
Sick5 is offline   Reply With Quote
Old 10-14-2011, 09:28 AM   #2
Clyde65
Clyde65's Avatar
Re: frontend help
One on inside of inner fender ( both sides) two at door, one at bottom of fender at door. then you have two at core support under the truck, those are a little hard to get to.
If I may suggest. I wouldnt pull any sheet metal off, getting them to realign will be very time consuming and if your doing front suspension work, really isnt needed. But thats me.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-14-2011, 12:52 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: frontend help
i guess your right. i just thought i would make thing easier plus i can get some off the frame painted... oh by the way im also adding disc brake and drop spindels
Old 10-14-2011, 01:03 PM   #4
Clyde65
Clyde65's Avatar
Re: frontend help
I understand why you might do it, but I think with the work your gonna do, it will just complicate the job at hand. be sure to clean stuff up. I used a degreaser everyday for a week to get the gunk off, spraying with a high pressure hose after each applications, letting it soak in for an hour or so, then pressure hose it. then when you got everything off, wire brush, degrease, clean with soap and water, then paint.
Good luck!
Clyde65
Rebuild of Clyde
support our troops!
Old 10-14-2011, 07:08 PM   #5
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: frontend help
im might just do that instead. im sure the truck need it. hopefully i can start next weekend.
