Old 10-14-2011, 10:16 PM   #1
barnold
barnold's Avatar
Air Tank Location
I am building a 72 blazer. where is the best place to mount the tank that is out of sight. Pics would be great.
barnold is offline   Reply With Quote
Old 10-14-2011, 10:40 PM   #2
funkytechmonkey
funkytechmonkey's Avatar
Re: Air Tank Location
I assume you are talking about the air tanks....3 or 5 gallon?
I have 2 - 3 gallon tanks.. Here is where I mounted mine. Not a blazer but should work
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 10-14-2011, 10:53 PM   #3
barnold
barnold's Avatar
Yes the that is what i was talking about. the problem is the blazer has a rocker box that goes from the fire wall to the rear wheel tub. A truck does not have them.
Old 10-17-2011, 09:23 AM   #4
Rochlow
On the very rear of the truck right behind the passenger's rear wheel is where I mounted a three gallon. My compressor and valves are in the middle between the frame rails and just behind the gas tank.
Rochlow is offline   Reply With Quote
Old 10-17-2011, 10:34 AM   #5
Tony@AirRideTech
Junior Member
You can also mount them on the inside of the frame rail by partially boxing the frame for your mounts.
Tony@AirRideTech is offline   Reply With Quote
Old 10-17-2011, 10:35 AM   #6
Tony@AirRideTech
Junior Member
Also Funky.... I notice where you have your one pressure sensor heading uphill... great job putting it there but make sure you can service that thing with the body on
Old 10-17-2011, 04:16 PM   #7
kieth
kieth's Avatar
Funky, where is your air tank drain ?? looks like you have the 2 end plugs are on the top instead of the bottom to facilitate draining the water from the air tank ?? Kieth
My air tank is on the drivers side right where yours is.....only place I could find room. Kieth
kieth is offline   Reply With Quote
Old 10-18-2011, 03:23 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
Got any pics? Would a 5 gallon fit in the same location?
If you did this, how could you route the exhaust?
Not trying to steal the thread, but I didn't have a great spot for mine, so it's behind the rear seat. I'd love to mount it somewhere else one day along with all the valves...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-18-2011, 04:56 PM   #9
Rdrdave
Broke and still trying
Rdrdave's Avatar
I have a '72 4x4 blazer and it looks like the only place I could fit a viair 2.5gal tank is either above the pumpkin, or where the floor bumps up, or in the engine compartment. I've seen two other blazers put little tanks in the very back of the body where your exhaust would normally exit.
Rdrdave is offline   Reply With Quote
Old 10-18-2011, 07:08 PM   #10
Rochlow
I don't think a 5 gallon would fit back there..
Old 10-18-2011, 09:53 PM   #11
kev2809
low n' slo
kev2809's Avatar
could you guys mount it behind the gas tank, and before the tailgate area? thats where my 5 gallon is..not sure if suburban and blazer are different in that area.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
