Old 10-15-2011, 01:09 PM   #1
exploderjim
exploderjim's Avatar
LS@ engine mount
Can someone tell me if the Trailblazer SS LS2 will work with the ECE 63-72 Gen III Motor Mount Conversion Kit. I'm trying to put this LS2 in to my 72 2wd Blazer and I need a motor mount set up. I'm going to take the AWD oil pan off and put on the vette oil pan to reduce the height. Anyways, I know this motor is a Gen IV but I wasn't sure if it uses the same mount points as the Gen III. Any help would be appreciated.
Jim
Title should be LS2 sorry boys.
exploderjim is offline   Reply With Quote
Old 10-15-2011, 01:11 PM   #2
exploderjim
LS2 engine mounts
Can someone tell me if the Trailblazer SS LS2 will work 63-72 Gen III Motor Mount Conversion Kit. I'm trying to put this LS2 in to my 72 2wd Blazer and I need a motor mount set up. I'm going to take the AWD oil pan off and put on the vette oil pan to reduce the height. Anyways, I know this motor is a Gen IV but I wasn't sure if it uses the same mount points as the Gen III. Any help would be appreciated.
Jim
Old 10-15-2011, 01:32 PM   #3
truckdude239
truckdude239's Avatar
Re: LS@ engine mount
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-15-2011, 02:08 PM   #4
exploderjim
I was trying to correct the Title of the post. Go ahead and remove the offending one.
Old 10-15-2011, 09:02 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Jim
GENIV and GENIII use the same mount patterns. So yes it will work.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-16-2011, 09:00 AM   #6
exploderjim
Thanks usmcchevy. I appreciate the help.
